gen 1 abs unit
smegun
deltona, fl
can i install a pull from the yard without having to reprogram like i recall making a backup for what it is worth not much there seems in forscan for file i assume id have to but that convo was for gen2 and not certain ..... also not very much there in options for modules when i did try havent upgraded forscan for some time hoping i could get more out of it since investing and getting downloadables from motorcraft files seemed to go ok yaw test program works to shut off the abs light for some reason but the ABS bleed progy was no go
joegr
Gulfport
If you have AdvanceTrac, you will have to run a calibrate routine.
joegr
Gulfport
Yes, Forscan can initiate the calibrate routine.
Staff online
