Gas
dropped74
Pensacola
I am in Pensacola Fl and it is very hard to even find gas and impossible to find Premium. I have put one tank in and added the octane booster. If it continues to be hard to find prem. fuel will I be okay to continue to do this??? Thanks for your time.
Cheers
Nolan
:Beer
Cheers
Nolan
:Beer
89 Octane works as well for me as 91 or 93. I have not tried 87 yet but it would probably work also without booster.
I have run 87, 89 and 91 octane in my 2004 V8LS here in SoCal.
I have had noticable pinging under hard accleration with 87, and good performance with maybe once in a great while ping on 89, and fine with 91.
A lot would depend on temperature and air conditions plus how you drive.
If you drive like a granny with mostly freeway driving on flat land, you could probably run just about anything for some time. If you are a hard driver in hot weather in lots of hills, you would need to move higher in octane.
For a little while you are probably OK with 87, I prefer 89. Best bet is 91 but you have a problem finding it.
Note that most Octane Boosters I have seen have fine print that says you have to use several cans per tankfull to move the octane any significant amount.
If it was me I would drive with 89 and forget booster. If I had to, I would use 87 without booster and drive gently.
Some people would swear your engine will grenade if you use anything less than 91. I tend to disagree since I have seen articles over the years about this and I would hope Ford would make an engine that isn't so delicate that it blows up if you look at it wrong. I could be wrong. Plus I have been running 89 pretty frequently since about April and haven't exploded anything, yet. Course the manual Recommends 91. Not the same as required.
Good Luck,
Jim Henderson
it would work but i wouldnt recomend
but hey you might her a knocing noice after a little man
Good Luck,
Jim Henderson
I tend to agree with your advice. I have always used 89 in my 2002 LS V8 without any hint of a ping. I drive my car hard and the summers are very hot in Georgia. Why would Ford use knock sensors and computer if you could only use premium fuels?
