IF that is the vapor line, then it is really just a vacuum hose, but with special fittings at each end. I think that the first thing to do is to determine if the hose hanging there is the vapor line.
The vapor line connects under the hood to the purge valve. It's over the left (driver's) wheel. This may help.
Item Part Number Description
4 9D676 Fuel tube
5 — Vapor tube quick connect coupling (part of 9J274)
6 — Vapor tube quick connect coupling (part of 9J274)
And this shows the line as it goes under the car to the tank.
13 W705549 Fuel hose bracket mounting bolt
14 N803882 Fuel hose bracket mounting bolt
15 9S284 Fuel tube
16 W500212 Fuel tube mounting bolt (5 required)
17 W503924 Fuel tube shield mounting bolt
18 — Fuel tube shield pin-type retainer
19 N804795 Fuel tube shield mounting nut (3 required)
20 9C291 Fuel tube shield
21 — Fuel vapor tube quick connect coupling (part of 9J274)
- For additional information, refer to the procedures in this section.
