Hello All,
Quick background on the vehicle. 2004 LS 115k miles on it. I have been getting a CEL, I forgot the actual code it is throwing, ill post it next time it comes up, but it is "fuel pressure circuit high voltage" or something along those lines. I mentioned it to a mechanic last time i took it in and he kind of blew it off. Anywho while driving around town my fuel rail pressure (relative to manifold) is between 54 and 56 psi. But when I get on the highway it immediately jumps to 74.2 psi and stays solid while on cruise control. if i am going highway speeds and push on the gas the FRP drops back down to 54ish as it accelerates. If i hold the pedal steady it will bounce from the 54's to 74.2 with no real pattern or rhyme or reason. Some times when i first start the car and A/C is on I get a whiff of gas for a few seconds and then goes away. Any suggestions on where to start with this? Could this be a leaking fuel rail? or im kind of hoping just a sensor that went bad.
I am not sure if it is related or not but this morning while i was sitting in my car i noticed that while idling every 10-15 seconds or so it sounds like the exhaust kind of "flutters" for a breif moment, sometimes associated with a momentarily drop in engine RPM. The A/C and heat were off while i was sitting there so it's not anything associated with the A/C compressor flipping on that usually drops rpm briefly. This is much quicker than that. It almost sounds like a misfire but when I checked it, it didn't show any misfires in any cylinder over the last 10 driving cycles. I bring this up in case these 2 issues are related in any way.
I travel a lot for work so while I can do most things myself, I don't really have much time available to tinker around with things.
Thanks for your help.
