cpgoodman
Ok so i have a 01 V6 LS. i got hit in the front left wheel area. Nothing too major but they totaled the car out anyway. So i kept the car and am currently getting it fixed. The body shop called and said that it wouldnt start and i need a new fuel pump. I went down their to inspect for myself.
I checked the reset switch in the drivers kick and that was fine, had power on both sides of the switch. In the rear fuse block fuse #17 was blown which is the fuel pump (no others where blown). Replaced that and still cranks but wont start. Next i swapped out relay #7 in the back fuse box and still nothing. Then i pulled up the back seat and metered the wires on both pumps. On the right main pump i have 4 wires,2 hot and 2 ground. On the left jet pump i have 2 grounds. If i unplug the jet pump from the harness one of the grounds trips to 12v power. This is where im stuck. I dont know which pump to get to replace. If the jet pump where out would it cause the whole system not to work? I would think it would work until you needed the gas from the other side. Anybody with any input? I dont have the funds to replace both. Worse its down at the body shop so its not that easy to go work on it as i think about it.
Please help!
Please help!
