I'm putting a 98 4.6L DOHC in a Mazda Truck and have been trying to get it started.
What appears to be happening is the PCM is not grounding the fuel pump relay so it will turn on.
As soon as I ground the lead the pump will turn on and it will fire.
I flashed the PCM with Sniper and turned off PATS.
Is there something I'm missing???? Looks like the PCM is not turning the pump on for some reason!!!
Thanx
Thanx
