Frustrated please any ideas?
Lincoln LS
  1. Dougmcmullen
    Dougmcmullen LVC Member
    15
    Nov 17, 2019
    46550
    01 lincoln ls v8 replaced gas still showing check gas cap no leaks vaccum or otherwise had a emissions leak line replaced any ideas
  2. AmsterDutch
    AmsterDutch Dedicated LVC Member
    1,989
    336
    Jul 9, 2017
    Midwest
    Did you try a new gas cap? I was battling this same issue with my 2006 LS final after buying the third gas cap it was happy again :)
  3. 04_Sport_LS
    04_Sport_LS Dedicated LVC Member
    3,592
    426
    Jun 12, 2012
    Somewhere around Lake Erie
    The fuel cap at O'Reilly's, (if it is still made in Israel), is a good one.
    Also... make sure the filler neck where the gas cap seals... is clean. It tends to get dirt buildup on it... preventing a good seal.
    I make it a habit to wipe off the neck with a damp paper towel when refueling.
  4. mkc
    mkc LVC Member
    36
    6
    Jan 22, 2017
    middle TN
    Any particular codes?
    There are a couple of previous discussions on the forum that might help as well. Here's one that came up in a quick Google search Gas Cap There were at least 4 or 5 others when I searched on Lincoln LS Check Fuel Cap
  5. 04_Sport_LS
    3,592
    426
    Jun 12, 2012
    Thanks MKC. I was being lazy and didn't feel like using the forum search function.
    IIRC... one of the issues could also be a seal or bad vent valve at the tank.
    IIRC... another issue could also be an evap/purge cannister or solenoid in the engine bay.
  6. 04_Sport_LS
    3,592
    426
    Jun 12, 2012
    And yes... most times Google is better when searched by typing such as the below search.
    "lincoln ls gas cap site:lincolnvscadillac.com"
  7. MarkEricRoth
    MarkEricRoth LVC Member
    24
    3
    Jun 15, 2018
    Philly
    Thank you for the search tip 04_Sport_LS. I could never figure out why some search's got me right to the point and others got me nowhere. Now to try it out on the ... FEOA website.
  8. 04_Sport_LS
    3,592
    426
    Jun 12, 2012
    You're welcome
    With the forum search function... there is a fine line between being too specific... and not specific enough.
    Google definitely filters better and easier
    • Agree Agree x 1
    • milehighmikey
      milehighmikey Dedicated LVC Member
      792
      53
      Apr 2, 2007
      Nashua
      There is a really easy check of the evap purge valve that you can do. All that is needed is a small hand held vacuum pump. You take the hose off the valve at the most convenient location, and apply vacuum with a hand held pump to the valve. It should hold vacuum. If it does not, there is at least your first leak. Check youtube for evaporative canister purge valve diagnosis, easiest test ever. $30 USD for that handheld vacuum pump.
      • Like Like x 1
      Share This Page
