Travis2000LS
Tore my car apart today.. Turns out the exhaust cam was off a tooth on timing.. Problem is now.. my noise is back from being gone for 4 days.. :/ we will see if noise goes away!
So this was done a year ago do you have any documentation like a receipt I will go back there and give them a piece if my mind or boot that's alot for a issue that didn't go away.
I ordered a Jaguar 4th-gen secondary tensioner and it is due to be delivered today (on ebay for $74!), so as soon as I get out of work, I am going to replace that tensioner, realign the cam flats and tighten everything back up.
Hopefully this will clear up the noise.
If there were bent valves or anything like that, the car wouldn't run as good as it does when I drive it. The only issue I had was a rough idle and noisy "lifter" sounds at idle. It seems to dissipate when I drive it and the car runs smooth with plenty of power when driven. So hopefully I caught it early enough and was smart enough to park my car and not drive it.
I will post an update this evening, after I get nitty gritty....
If the idle is rough.. the Exhaust cam timing is probably off a tooth like mine was... Its so disappointing.. Fixed the idle issue on my car by lining up the flats of the cams.. fixed the running rich on bank 1 and lean on bank 2, misfire, idle, and check engine light.. BUT THe noise.. WONT GO AWAY!
switching to a mazda miata..
Are you serious? I would rather buy a bus pass
Well I still have to buy a new chain for mine. But now my Beloved LS has decided to Overheat now :/
Due to the Fan not kicking into high and low speeds during Running temps..
Works fine for about 10 minutes when you first start it up. But after that the fan just stays on a low setting.. Yay..
Going to buy a new Actuator for it today for 150$.:/
Then buy a new Chain
Lmfao, I fell in love with the LS.. But its pissing me off everything breaking on it! and im just HOPING that its the actuator.. if I pay 150$ for something that it doesnt even need im going to be F&^ked royally because Im on a VERY tight budget atm..
