Dave 88 LSC
After replacing most of the front end bushings with OEM parts, I am hearing a very faint humm coming from a driver side front wheel. I am not sure if it is normal or out of spec. It could be a bad tire for all I know. I've had cars that had a bad tire that sounded like a bad wheel bearing. I did not do wheel alignment since changing all those parts since the car rides well and tracks straight.
How can I check if the bearing is good or bad? There is no play while checking the wheel on that particular side. I don't want to wait till the wheel falls off.
How hard or expensive is it to change a front wheel bearing.
Thank you for your inputs.
Dave
Dave
