Front Sway bar end links
toomanymustangs
Bethel Springs
Is there a set of aftermarket front sway bar end links for a Mark VIII?
I talked to Engery Suspensions and they were not much help.
I need to replace mine and want to upgrade to something other then the factory rubber set up.
Thanks
end links? what wrong with the TRW ones? thats what the factory used.
but "factory rubber set up" makes me think you are talking about sway bar bushings instead? as there is no rubber in the end links except for the boot. in which case, measure your sway bar, and purchase the appropriate size.
What he said. The factory end links are a ball and socket design like a ball joint.
-Alan
