Kevin
Doing brakes on the 94,
Using a clamp to squeeze the caliper piston back, to allow clearance for new pads+rotors.
The piston will move in, then when pressure is released on the clamp - the piston slides out.
The cap is off the fluid reservoir under the hood.
What I've done for now, is put the old pads back on (1/8" left), but obviously a mismatched setup isn't good, and I have a new set of pads for the new rotor.
Halp!
Halp!
