nelliott500
Not 100% of the problem yet. Went to remove my rear-passenger tire today to do the brakes and one of the lugs was really tight. I turned it with the socket quite a few times and it would get loose and tight over and over again. Then I realized I couldn't tighten it now either. It's only loose a little bit, but if you wiggle it, it seems like the whole stud is moving around. The stud isn't broken either. I took the other lugs off and still couldn't get the wheel off. I tried pulling on the wheel to keep pressure on the lug while loosening it and it didn't make a difference.
Any ideas? I'm assuming the stud needs to be replaced, but how the :q:q:q:q do I do that if I can't get the wheel off?
Figured I would get some opinions before I go to my mechanic on Tuesday to have them check it out.
