That damage totalled the car. I owed $6k, they valued it at $9k, cut me a check for $3k and i was sent on my way. The only way i can explain that accident is that it was an act from god above. I was on an on-ramp for a highway which was a right turn, uphill, banked slightly, pretty sharp. The speed limit on it is 25 mph which is about all you can do in any car due to its characteristics. The road wasnt "wet" but it had rained earlier in the day. Just had 4 new tires put on about two weeks earlier. At the top of the ramp i look over my left shoulder, see the road is clear to merge.....hit the gas slightly, car takes a HARD pull to the right and smacks the guard rail and i continue in a right hand spin for a complete 360 facing back down the ramp. Wasnt due to rear wheel spin, i didnt jerk the wheel, it just felt like the car hit a magnetic field and instantly dived into the guard rail. Only the passenger airbag went off due to the impact point being about at the right headlight area. The impact caused the front end to just explode into pieces, and yes that is just regular 'ol styrofoam, nothing fancy. After all the plastic and foam was gone it pushed all the front engine components back, lots of mechanical damage. The fastest i could have been going on impact was 30 mph, most likely less. It was a metal guard rail that only showed some scuffing afterwards, not even bent one bit. Strange event.
