Ford OBD Trouble Codes LIST
Lincoln Jealous
P0010-P0099 – Fuel and Air Metering and Auxiliary Emission Controls
* P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
* P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
* P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
* P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
* P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
* P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
* P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
* P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
* P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
* P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
* P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
* P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
* P0030 HO2S Heater Control
Circuit (Bank 1 Sensor 1)
* P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
* P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
* P0033 Turbo Charger Bypass Valve Control Circuit
* P0034 Turbo Charger Bypass Valve Control Circuit Low
* P0035 Turbo Charger Bypass Valve Control Circuit High
* P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
* P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
* P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
* P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
* P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
* P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
* P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
* P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
* P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
* P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
* P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
* P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
* P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
* P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
* P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
* P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
* P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
* P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
* P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
* P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
* P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
* P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
* P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
* P0065 Air Assisted Injector Control Range/Performance
* P0066 Air Assisted Injector Control Circuit or Circuit Low
* P0067 Air Assisted Injector Control Circuit High
* P0070 Ambient Air Temperature Sensor Circuit
* P0071 Ambient Air Temperature Sensor Range/Performance
* P0072 Ambient Air Temperature Sensor Circuit Low Input
* P0073 Ambient Air Temperature Sensor Circuit High Input
* P0074 Ambient Air Temperature Sensor Circuit Intermittent
* P0075 Intake Valve Control Solenoid Circuit (Bank 1)
* P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
* P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
* P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
* P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
* P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
* P0081 Intake valve Control Solenoid Circuit (Bank 2)
* P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
* P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
* P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
* P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
* P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
DTC Codes - P0100-P0199 � Fuel and Air Metering
* P0100 Mass or Volume Air Flow Circuit Malfunction
* P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
* P0102 Mass or Volume Air Flow Circuit Low Input
* P0103 Mass or Volume Air Flow Circuit High Input
* P0104 Mass or Volume Air Flow Circuit Intermittent
* P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
* P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
* P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
* P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
* P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
* P0109 Intake Air Temperature Circuit Malfunction
* P0111 Intake Air Temperature Circuit Range/Performance Problem
* P0112 Intake Air Temperature Circuit Low Input
* P0113 Intake Air Temperature Circuit High Input
* P0114 Intake Air Temperature Circuit Intermittent
* P0115 Engine Coolant Temperature Circuit Malfunction
* P0116 Engine Coolant Temperature Circuit Range/Performance Problem
* P0117 Engine Coolant Temperature Circuit Low Input
* P0118 Engine Coolant Temperature Circuit High Input
* P0119 Engine Coolant Temperature Circuit Intermittent
* P0120 Throttle Position Sensor/Switch A Circuit Malfunction
* P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
* P0122 Throttle Position Sensor/Switch A Circuit Low Input
* P0123 Throttle Position Sensor/Switch A Circuit High Input
* P0124 Throttle Position Sensor/Switch A Circuit Intermittent
* P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
* P0126 Insufficient Coolant Temperature for Stable Operation
* P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
* P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
* P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
* P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
* P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
* P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
* P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
* P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
* P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
* P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
* P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
* P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
* P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
* P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
* P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
* P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
* P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
* P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
* P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
* P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
* P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
* P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
* P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
* P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
* P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
* P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
* P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
* P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
* P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
* P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
* P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
* P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
* P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
* P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
* P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
* P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
* P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
* P0170 Fuel Trim Malfunction (Bank 1)
* P0171 System too Lean (Bank 1)
* P0172 System too Rich (Bank 1)
* P0173 Fuel Trim Malfunction (Bank 2)
* P0174 System too Lean (Bank 2)
* P0175 System too Rich (Bank 2)
* P0176 Fuel Composition Sensor Circuit Malfunction
* P0177 Fuel Composition Sensor Circuit Range/Performance
* P0178 Fuel Composition Sensor Circuit Low Input
* P0179 Fuel Composition Sensor Circuit High Input
* P0180 Fuel Temperature Sensor A Circuit Malfunction
* P0181 Fuel Temperature Sensor A Circuit Range/Performance
* P0182 Fuel Temperature Sensor A Circuit Low Input
* P0183 Fuel Temperature Sensor A Circuit High Input
* P0184 Fuel Temperature Sensor A Circuit Intermittent
* P0185 Fuel Temperature Sensor B Circuit Malfunction
* P0186 Fuel Temperature Sensor B Circuit Range/Performance
* P0187 Fuel Temperature Sensor B Circuit Low Input
* P0188 Fuel Temperature Sensor B Circuit High Input
* P0189 Fuel Temperature Sensor B Circuit Intermittent
* P0190 Fuel Rail Pressure Sensor Circuit Malfunction
* P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
* P0192 Fuel Rail Pressure Sensor Circuit Low Input
* P0193 Fuel Rail Pressure Sensor Circuit High Input
* P0194 Fuel Rail Pressure Sensor Circuit Intermittent
* P0195 Engine Oil Temperature Sensor Malfunction
* P0196 Engine Oil Temperature Sensor Range/Performance
* P0197 Engine Oil Temperature Sensor Low
* P0198 Engine Oil Temperature Sensor High
* P0199 Engine Oil Temperature Sensor Intermittent
DTC Codes - P0200-P0299 � Fuel and Air Metering (Injector Circuit)
* P0200 Injector Circuit Malfunction
* P0201 Injector Circuit Malfunction - Cylinder 1
* P0202 Injector Circuit Malfunction - Cylinder 2
* P0203 Injector Circuit Malfunction - Cylinder 3
* P0204 Injector Circuit Malfunction - Cylinder 4
* P0205 Injector Circuit Malfunction - Cylinder 5
* P0206 Injector Circuit Malfunction - Cylinder 6
* P0207 Injector Circuit Malfunction - Cylinder 7
* P0208 Injector Circuit Malfunction - Cylinder 8
* P0209 Injector Circuit Malfunction - Cylinder 9
* P0210 Injector Circuit Malfunction - Cylinder 10
* P0211 Injector Circuit Malfunction - Cylinder 11
* P0212 Injector Circuit Malfunction - Cylinder 12
* P0213 Cold Start Injector 1 Malfunction
* P0214 Cold Start Injector 2 Malfunction
* P0215 Engine Shutoff Solenoid Malfunction
* P0216 Injection Timing Control Circuit Malfunction
* P0217 Engine Overtemp Condition
* P0218 Transmission Over Temperature Condition
* P0219 Engine Overspeed Condition
* P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
* P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
* P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
* P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
* P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
* P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
* P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
* P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
* P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
* P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
* P0230 Fuel Pump Primary Circuit Malfunction
* P0231 Fuel Pump Secondary Circuit Low
* P0232 Fuel Pump Secondary Circuit High
* P0233 Fuel Pump Secondary Circuit Intermittent
* P0234 Engine Overboost Condition
* P0235 Turbocharger Boost Sensor A Circuit Malfunction
* P0236 Turbocharger Boost Sensor A Circuit Range/Performance
* P0237 Turbocharger Boost Sensor A Circuit Low
* P0238 Turbocharger Boost Sensor A Circuit High
* P0239 Turbocharger Boost Sensor B Malfunction
* P0240 Turbocharger Boost Sensor B Circuit Range/Performance
* P0241 Turbocharger Boost Sensor B Circuit Low
* P0242 Turbocharger Boost Sensor B Circuit High
* P0243 Turbocharger Wastegate Solenoid A Malfunction
* P0244 Turbocharger Wastegate Solenoid A Range/Performance
* P0245 Turbocharger Wastegate Solenoid A Low
* P0246 Turbocharger Wastegate Solenoid A High
* P0247 Turbocharger Wastegate Solenoid B Malfunction
* P0248 Turbocharger Wastegate Solenoid B Range/Performance
* P0249 Turbocharger Wastegate Solenoid B Low
* P0250 Turbocharger Wastegate Solenoid B High
* P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
* P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
* P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
* P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
* P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
* P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
* P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector)
* P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R
* P0259 Injection Pump Fuel Metering Control "B" High (Cam/R
* P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector)
* P0261 Cylinder I Injector Circuit Low
* P0262 Cylinder I Injector Circuit High
* P0263 Cylinder I Contribution/Balance Fault
* P0264 Cylinder 2 Injector Circuit Low
* P0265 Cylinder 2 Injector Circuit High
* P0266 Cylinder 2 Contribution/Balance Fault
* P0267 Cylinder 3 Injector Circuit Low
* P0268 Cylinder 3 Injector Circuit High
* P0269 Cylinder 3 Contribution/Balance Fault
* P0270 Cylinder 4 Injector Circuit Low
* P0271 Cylinder 4 Injector Circuit High
* P0272 Cylinder 4 Contribution/Balance Fault
* P0273 Cylinder 5 Injector Circuit Low
* P0274 Cylinder 5 Injector Circuit High
* P0275 Cylinder S Contribution/Balance Fault
* P0276 Cylinder 6 Injector Circuit Low
* P0277 Cylinder 6 Injector Circuit High
* P0278 Cylinder 6 Contribution/Balance Fault
* P0279 Cylinder 7 Injector Circuit Low
* P0280 Cylinder 7 Injector Circuit High
* P0281 Cylinder 7 Contribution/Balance Fault
* P0282 Cylinder 8 Injector Circuit Low
* P0283 Cylinder 8 Injector Circuit High
* P0284 Cylinder 8 Contribution/Balance Fault
* P0285 Cylinder 9 Injector Circuit Low
* P0286 Cylinder 9 Injector Circuit High
* P0287 Cylinder 9 Contribution/Balance Fault
* P0288 Cylinder 10 Injector Circuit Low
* P0289 Cylinder 10 Injector Circuit High
* P0290 Cylinder 10 Contribution/Balance Fault
* P0291 Cylinder 11 Injector Circuit Low
* P0292 Cylinder 11 Injector Circuit High
* P0293 Cylinder 11 Contribution/Balance Fault
* P0294 Cylinder 12 Injector Circuit Low
* P0295 Cylinder 12 Injector Circuit High
* P0296 Cylinder 12 Contribution/Range Fault
DTC Codes - P0300-P0399 � Ignition System or Misfire
* P0300 Random/Multiple Cylinder Misfire Detected
* P0301 Cylinder 1 Misfire Detected
* P0302 Cylinder 2 Misfire Detected
* P0303 Cylinder 3 Misfire Detected
* P0304 Cylinder 4 Misfire Detected
* P0305 Cylinder 5 Misfire Detected
* P0306 Cylinder 6 Misfire Detected
* P0307 Cylinder 7 Misfire Detected
* P0308 Cylinder 8 Misfire Detected
* P0309 Cylinder 9 Misfire Detected
* P0310 Cylinder 10 Misfire Detected
* P0311 Cylinder 11 Misfire Detected
* P0312 Cylinder 12 Misfire Detected
* P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
* P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
* P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
* P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
* P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
* P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
* P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
* P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
* P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
* P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
* P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
* P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
* P0333 Knock Sensor 2 Circuit High Input (Bank 2)
* P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
* P0335 Crankshaft Position Sensor A Circuit Malfunction
* P0336 Crankshaft Position Sensor A Circuit Range/Performance
* P0337 Crankshaft Position Sensor A Circuit Low Input
* P0338 Crankshaft Position Sensor A Circuit High Input
* P0339 Crankshaft Position Sensor A Circuit Intermittent
* P0340 Camshaft Position Sensor Circuit Malfunction
* P0341 Camshaft Position Sensor Circuit Range/Performance
* P0342 Camshaft Position Sensor Circuit Low Input
* P0343 Camshaft Position Sensor Circuit High Input
* P0344 Camshaft Position Sensor Circuit Intermittent
* P0350 Ignition Coil Primary/Secondary Circuit Malfunction
* P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
* P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
* P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
* P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
* P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
* P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
* P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
* P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
* P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
* P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
* P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
* P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
* P0370 Timing Reference High Resolution Signal A Malfunction
* P0371 Timing Reference High Resolution Signal A Too Many Pulses
* P0372 Timing Reference High Resolution Signal A Too Few Pulses
* P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
* P0374 Timing Reference High Resolution Signal A No Pulses
* P0375 Timing Reference High Resolution Signal B Malfunction
* P0376 Timing Reference High Resolution Signal B Too Many Pulses
* P0377 Timing Reference High Resolution Signal B Too Few Pulses
* P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
* P0379 Timing Reference High Resolution Signal B No Pulses
* P0380 Glow Plug/Heater Circuit "A" Malfunction
* P0381 Glow Plug/Heater Indicator Circuit Malfunction
* P0382 Exhaust Gas Recirculation Flow Malfunction
* P0385 Crankshaft Position Sensor B Circuit Malfunction
* P0386 Crankshaft Position Sensor B Circuit Range/Performance
* P0387 Crankshaft Position Sensor B Circuit Low Input
* P0388 Crankshaft Position Sensor B Circuit High Input
* P0389 Crankshaft Position Sensor B Circuit Intermittent
DTC Codes - P0400-P0499 � Auxiliary Emissions Controls
* P0400 Exhaust Gas Recirculation Flow Malfunction
* P0401 Exhaust Gas Recirculation Flow Insufficient Detected
* P0402 Exhaust Gas Recirculation Flow Excessive Detected
* P0403 Exhaust Gas Recirculation Circuit Malfunction
* P0404 Exhaust Gas Recirculation Circuit Range/Performance
* P0405 Exhaust Gas Recirculation Sensor A Circuit Low
* P0406 Exhaust Gas Recirculation Sensor A Circuit High
* P0407 Exhaust Gas Recirculation Sensor B Circuit Low
* P0408 Exhaust Gas Recirculation Sensor B Circuit High
* P0410 Secondary Air Injection System Malfunction
* P0411 Secondary Air Injection System Incorrect Flow Detected
* P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
* P0413 Secondary Air Injection System Switching Valve A Circuit Open
* P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
* P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
* P0416 Secondary Air Injection System Switching Valve B Circuit Open
* P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
* P0418 Secondary Air Injection System Relay �A" Circuit Malfunction
* P0419 Secondary Air Injection System Relay "B� Circuit Malfunction
* P0420 Catalyst System Efficiency Below Threshold (Bank 1)
* P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
* P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
* P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
* P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
* P0430 Catalyst System Efficiency Below Threshold (Bank 2)
* P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
* P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
* P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
* P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
* P0440 Evaporative Emission Control System Malfunction
* P0441 Evaporative Emission Control System Incorrect Purge Flow
* P0442 Evaporative Emission Control System Leak Detected (small leak)
* P0443 Evaporative Emission Control System Purge Control Valve Circuit
* P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
* P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
* P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
* P0447 Evaporative Emission Control System Vent Control Circuit Open
* P0448 Evaporative Emission Control System Vent Control Circuit Shorted
* P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
* P0450 Evaporative Emission Control System Pressure Sensor Malfunction
* P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
* P0452 Evaporative Emission Control System Pressure Sensor Low Input
* P0453 Evaporative Emission Control System Pressure Sensor High Input
* P0454 Evaporative Emission Control System Pressure Sensor Intermittent
* P0455 Evaporative Emission Control System Leak Detected (gross leak)
* P0456 Evaporative Emissions System - Small leak detected
* P0457
* P0458
* P0459
* P0460 Fuel Level Sensor Circuit Malfunction
* P0461 Fuel Level Sensor Circuit Range/Performance
* P0462 Fuel Level Sensor Circuit Low Input
* P0463 Fuel Level Sensor Circuit High Input
* P0464 Fuel Level Sensor Circuit Intermittent
* P0465 Purge Flow Sensor Circuit Malfunction
* P0466 Purge Flow Sensor Circuit Range/Performance
* P0467 Purge Flow Sensor Circuit Low Input
* P0468 Purge Flow Sensor Circuit High Input
* P0469 Purge Flow Sensor Circuit Intermittent
* P0470 Exhaust Pressure Sensor Malfunction
* P0471 Exhaust Pressure Sensor Range/Performance
* P0472 Exhaust Pressure Sensor Low
* P0473 Exhaust Pressure Sensor High
* P0474 Exhaust Pressure Sensor Intermittent
* P0475 Exhaust Pressure Control Valve Malfunction
* P0476 Exhaust Pressure Control Valve Range/Performance
* P0477 Exhaust Pressure Control Valve Low
* P0478 Exhaust Pressure Control Valve High
* P0479 Exhaust Pressure Control Valve Intermittent
* P0480 Cooling Fan I Control Circuit Malfunction
* P0481 Cooling Fan 2 Control Circuit Malfunction
* P0482 Cooling Fan 3 Control Circuit Malfunction
* P0483 Cooling Fan Rationality Check Malfunction
* P0484 Cooling Fan Circuit Over Current
* P0485 Cooling Fan Power/Ground Circuit Malfunction
DTC Codes - P0500-P0599 � Vehicle Speed Controls and Idle Control System
* P0500 Vehicle Speed Sensor Malfunction
* P0501 Vehicle Speed Sensor Range/Performance
* P0502 Vehicle Speed Sensor Low Input
* P0503 Vehicle Speed Sensor Intermittent/Erratic/High
* P0505 Idle Control System Malfunction
* P0506 Idle Control System RPM Lower Than Expected
* P0507 Idle Control System RPM Higher Than Expected
* P0510 Closed Throttle Position Switch Malfunction
* P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
* P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
* P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
* P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
* P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
* P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
* P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
* P0533 A/C Refrigerant Pressure Sensor Circuit High Input
* P0534 Air Conditioner Refrigerant Charge Loss
* P0550 Power Steering Pressure Sensor Circuit Malfunction
* P0551 Power Steering Pressure Sensor Circuit Range/Performance
* P0552 Power Steering Pressure Sensor Circuit Low Input
* P0553 Power Steering Pressure Sensor Circuit High Input
* P0554 Power Steering Pressure Sensor Circuit Intermittent
* P0560 System Voltage Malfunction
* P0561 System Voltage Unstable
* P0562 System Voltage Low
* P0563 System Voltage High
* P0565 Cruise Control On Signal Malfunction
* P0566 Cruise Control Off Signal Malfunction
* P0567 Cruise Control Resume Signal Malfunction
* P0568 Cruise Control Set Signal Malfunction
* P0569 Cruise Control Coast Signal Malfunction
* P0570 Cruise Control Accel Signal Malfunction
* P0571 Cruise Control/Brake Switch A Circuit Malfunction
* P0572 Cruise Control/Brake Switch A Circuit Low
* P0573 Cruise Control/Brake Switch A Circuit High
* P0574 Cruise Control Related Malfunction
* P0575 Cruise Control Related Malfunction
* P0576 Cruise Control Related Malfunction
* P0578 Cruise Control Related Malfunction
* P0579 Cruise Control Related Malfunction
* P0580 Cruise Control Related Malfunction
DTC Codes - P0600-P0699 � Computer Output Circuit
* P0600 Serial Communication Link Malfunction
* P0601 Internal Control Module Memory Check Sum Error
* P0602 Control Module Programming Error
* P0603 Internal Control Module Keep Alive Memory (KAM) Error
* P0604 Internal Control Module Random Access Memory (RAM) Error
* P0605 Internal Control Module Read Only Memory (ROM) Error
* P0606 PCM Processor Fault
* P0608 Control Module VSS Output "A� Malfunction
* P0609 Control Module VSS Output "B" Malfunction
* P0620 Generator Control Circuit Malfunction
* P0621 Generator Lamp "L" Control Circuit Malfunction
* P0622 Generator Field "F" Control Circuit Malfunction
* P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
* P0654 Engine RPM Output Circuit Malfunction
* P0655 Engine Hot Lamp Output Control Circuit Malfunction
* P0656 Fuel Level Output Circuit Malfunction
DTC Codes - P0700-P0899 � Transmission
* P0700 Transmission Control System Malfunction
* P0701 Transmission Control System Range/Performance
* P0702 Transmission Control System Electrical
* P0703 Torque Converter/Brake Switch B Circuit Malfunction
* P0704 Clutch Switch Input Circuit Malfunction
* P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
* P0706 Transmission Range Sensor Circuit Range/Performance
* P0707 Transmission Range Sensor Circuit Low Input
* P0708 Transmission Range Sensor Circuit High Input
* P0709 Transmission Range Sensor Circuit Intermittent
* P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
* P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
* P0712 Transmission Fluid Temperature Sensor Circuit Low Input
* P0713 Transmission Fluid Temperature Sensor Circuit High Input
* P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
* P0715 Input/Turbine Speed Sensor Circuit Malfunction
* P0716 Input/Turbine Speed Sensor Circuit Range/Performance
* P0717 Input/Turbine Speed Sensor Circuit No Signal
* P0718 Input/Turbine Speed Sensor Circuit Intermittent
* P0719 Torque Converter/Brake Switch B Circuit Low
* P0720 Output Speed Sensor Circuit Malfunction
* P0721 Output Speed Sensor Range/Performance
* P0722 Output Speed Sensor No Signal
* P0723 Output Speed Sensor Intermittent
* P0724 Torque Converter/Brake Switch B Circuit High
* P0725 Engine Speed input Circuit Malfunction
* P0726 Engine Speed Input Circuit Range/Performance
* P0727 Engine Speed Input Circuit No Signal
* P0728 Engine Speed Input Circuit Intermittent
* P0730 Incorrect Gear Ratio
* P0731 Gear I Incorrect ratio
* P0732 Gear 2 Incorrect ratio
* P0733 Gear 3 Incorrect ratio
* P0734 Gear 4 Incorrect ratio
* P0735 Gear 5 Incorrect ratio
* P0736 Reverse incorrect gear ratio
* P0740 Torque Converter Clutch Circuit Malfunction
* P0741 Torque Converter Clutch Circuit Performance or Stuck Off
* P0742 Torque Converter Clutch Circuit Stock On
* P0743 Torque Converter Clutch Circuit Electrical
* P0744 Torque Converter Clutch Circuit Intermittent
* P0745 Pressure Control Solenoid Malfunction
* P0746 Pressure Control Solenoid Performance or Stuck Off
* P0747 Pressure Control Solenoid Stuck On
* P0748 Pressure Control Solenoid Electrical
* P0749 Pressure Control Solenoid Intermittent
* P0750 Shift Solenoid A Malfunction
* P0751 Shift Solenoid A Performance or Stuck Off
* P0752 Shift Solenoid A Stuck On
* P0753 Shift Solenoid A Electrical
* P0754 Shift Solenoid A Intermittent
* P0755 Shift Solenoid B Malfunction
* P0756 Shift Solenoid B Performance or Stock Off
* P0757 Shift Solenoid B Stuck On
* P0758 Shift Solenoid B Electrical
* P0759 Shift Solenoid B Intermittent
* P0760 Shift Solenoid C Malfunction
* P0761 Shift Solenoid C Performance or Stuck Off
* P0762 Shift Solenoid C Stuck On
* P0763 Shift Solenoid C Electrical
* P0764 Shift Solenoid C Intermittent
* P0765 Shift Solenoid D Malfunction
* P0766 Shift Solenoid D Performance or Stuck Off
* P0767 Shift Solenoid D Stuck On
* P0768 Shift Solenoid D Electrical
* P0769 Shift Solenoid D Intermittent
* P0770 Shift Solenoid E Malfunction
* P0771 Shift Solenoid E Performance or Stuck Off
* P0772 Shift Solenoid E Stuck On
* P0773 Shift Solenoid E Electrical
* P0774 Shift Solenoid E Intermittent
* P0780 Shift Malfunction
* P0781 1-2 Shift Malfunction
* P0782 2-3 Shift Malfunction
* P0783 3-4 Shift Malfunction
* P0784 4-5 Shift Malfunction
* P0785 Shift/Timing Solenoid Malfunction
* P0786 Shift/Timing Solenoid Range/Performance
* P0787 Shift/Timing Solenoid Low
* P0788 Shift/Timing Solenoid High
* P0789 Shift/Timing Solenoid Intermittent
* P0790 Normal/Performance Switch Circuit Malfunction
* P0801 Reverse Inhibit Control Circuit Malfunction
* P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
* P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1000 OBD-II Monitor Testing Incomplete
P1001 KOER Test Cannot Be Completed
P1039 Vehicle Speed Signal Missing or Improper
P1051 Brake Switch Signal Missing or Improper
P1100 Mass Air Flow Sensor Intermittent
P1101 Mass Air Flow Sensor out of Self-Test Range
P1112 Intake Air Temperature Sensor Intermittent
P1116 Engine Coolant Temperature Sensor is out of Self-Test Range
P1117 Engine Coolant Temperature Sensor Intermittent
P1120 Throttle Position Sensor out of range
P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
P1124 Throttle Position Sensor out of Self-Test Range
P1125 Throttle Position Sensor Intermittent
P1127 Heated Oxygen Sensor Heater not on During KOER Test
P1128 Heated Oxygen Sensor Signals reversed
P1129 Heated Oxygen Sensor Signals reversed
P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1135 Ignition Switch Signal Missing or Improper
P1137 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1138 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1150 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1157 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1158 Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1220 Series Throttle Control fault
P1224 Throttle Position Sensor B out of Self-Test Range
P1230 Open Power to Fuel Pump circuit
P1231 High Speed Fuel Pump Relay activated
P1232 Low Speed Fuel Pump Primary circuit failure
P1233 Fuel Pump Driver Module off-line
P1234 Fuel Pump Driver Module off-line
P1235 Fuel Pump Control out of range
P1236 Fuel Pump Control out of range
P1237 Fuel Pump Secondary circuit fault
P1238 Fuel Pump Secondary circuit fault
P1250 Lack of Power to FPRC Solenoid
P1260 Theft Detected - Engine Disabled
P1270 Engine RPM or Vehicle Speed Limiter Reached
P1288 Cylinder Head Temperature Sensor out of Self-Test Range
P1289 Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range
P1290 Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
P1299 Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309 Misfire Detection Monitor not enabled
P1351 Ignition Diagnostic Monitor circuit Input fault
P1352 Ignition Coil A - Primary circuit fault
P1353 Ignition Coil B - Primary circuit fault
P1354 Ignition Coil C - Primary circuit fault
P1355 Ignition Coil D - Primary circuit fault
P1356 Loss of Ignition Diagnostic Module Input to PCM
P1358 Ignition Diagnostic Monitor Signal out of Self-Test Range
P1359 Spark Output circuit fault
P1364 Ignition Coil Primary circuit fault
P1380 VCT Solenoid Valve circuit Short or Open
P1381 Cam Timing Advance is excessive
P1383 Cam Timing Advance is excessive
P1390 Octane Adjust out of Self-Test Range
P1400 Differential Pressure Feedback Electronic Sensor circuit Low Voltage
P1401 Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1403 Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405 Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
P1407 EGR No Flow Detected
P1408 EGR Flow out of Self-Test Range
P1409? EGR Vacuum Regulator circuit malfunction
P1409? Electronic Vacuum Regulator Control circuit fault
P1410 EGR Barometric Pressure Sensor VREF Voltage
P1411 Secondary Air is not being diverted
P1413 Secondary Air Injection System Monitor circuit Low Voltage
P1414 Secondary Air Injection System Monitor circuit High Voltage
P1442 Secondary Air Injection System Monitor circuit High Voltage
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1444 Purge Flow Sensor circuit Input Low
P1445 Purge Flow Sensor circuit Input High
P1450 Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1451 EVAP Control System Canister Vent Solenoid Circuit Malfunction
P1452 Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1455 Substantial Leak or Blockage in Evaporative Emission Control System
P1460 Wide Open Throttle Air Conditioning Cutoff circuit malfunction
P1461 Air Conditioning Pressure Sensor circuit Low Input
P1462 Air Conditioning Pressure Sensor circuit high Input
P1463 Air Conditioning Pressure Sensor Insufficient Pressure change
P1464 ACCS to PCM High During Self-Test
P1469 Low Air Conditioning Cycling Period
P1473 Fan Secondary High with Fans Off
P1474 Low Fan Control Primary circuit
P1479 High Fan Control Primary circuit
P1480 Fan Secondary Low with Low Fans On
P1481 Fan Secondary Low with High Fans On
P1483 Power to Cooling Fan Exceeded Normal Draw
P1484 Variable Load Control Module Pin 1 Open
P1500 Vehicle Speed Sensor Intermittent
P1501 Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure
P1502 Invalid or Missing Vehicle Speed Message or Brake Data
P1504 Intake Air Control circuit malfunction
P1505 Idle Air Control System at Adaptive Clip
P1506 Idle Air Control Over Speed Error
P1507 Idle Air Control Under Speed Error
P1512 Intake Manifold Runner Control Stuck Closed
P1513 Intake Manifold Runner Control Stuck Closed
P1516 Intake Manifold Runner Control Input Error
P1517 Intake Manifold Runner Control Input Error
P1518 Intake Manifold Runner Control fault - Stuck Open
P1519? Intake Manifold Runner Control Stuck Open
P1520? Intake Manifold Runner Control circuit fault
P1519? Intake Manifold Runner Control fault - Stuck Closed
P1520? Intake Manifold Runner Control fault
P1530 Open or Short to A/C Compressor Clutch circuit
P1537 Intake Manifold Runner Control Stuck Open
P1538 Intake Manifold Runner Control Stuck Open
P1539 Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw
P1549 Intake Manifold Temperature Valve Vacuum Actuator Connection
P1550 Power Steering Pressure Sensor out of Self-Test Range
P1605 PCM Keep Alive Memory Test Error
P1625 Voltage to Vehicle Load Control Module Fan circuit not detected
P1626 Voltage to Vehicle Load Control Module circuit not detected
P1650 Power Steering Pressure Switch out of Self-Test Range
P1651 Power Steering Pressure Switch Input fault
P1700 Transmission system problems
P1701 Reverse Engagement Error
P1702 Transmission system problems
P1703 Brake On/Off Switch out of Self-Test Range
P1704 Transmission system problems
P1705 Manual Lever Position Sensor out of Self-Test Range
P1709 Park or Neutral Position Switch out of Self-Test Range
P1710 Transmission system problems
P1711 Transmission Fluid Temperature Sensor out of Self-Test Range
P172 Transmission system problems
P1729 4x4 Low Switch Error
P1740 Transmission system problems
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Faulty
P1743 Torque Converter Clutch Solenoid Faulty
P1744 Torque Converter Clutch System Stuck in Off Position
P1745 Transmission system problems
P1746 Electronic Pressure Control Solenoid - Open circuit
P1747 Electronic Pressure Control Solenoid - Short circuit
P1749 Electronic Pressure Control Solenoid Failed Low
P1751 Shift Solenoid No. 1 Performance
P1754 Coast Clutch Solenoid circuit malfunction
P1756 Shift Solenoid No. 2 Performance
P1760 Transmission system problems
P1761 Shift Solenoid No. 3 Performance
P1762 Transmission system problems
P1767 Transmission system problems
P1780 Transmission Control Switch circuit is out of Self-Test Range
P1781 4x4 Low Switch is out of Self-Test Range
P1783 Transmission Over-Temperature Condition
P1784 Transmission system problems
P1785 Transmission system problems
P1786 Transmission system problems
P1787 Transmission system problems
P1788 Transmission system problems
P1789 Transmission system problems
P1900 Transmission system problems
Great list, but it's missing quite a few...
DTC Description Source Action
B1201 Fuel Sender Circuit Failure Rear Electronic Module (REM) REFER to Section 413-01 .
B1202 Fuel Sender Circuit Open Instrument Cluster REFER to Section 413-01 .
B1204 Fuel Sender Circuit Short to Ground Instrument Cluster REFER to Section 413-01 .
B1205 EIC Switch-1 Assembly Circuit Failure Instrument Cluster REFER to Section 413-01 .
B1205 EIC Switch-1 Assembly Circuit Failure Message Center REFER to Section 413-01 .
B1209 EIC Switch-2 Assembly Circuit Failure Instrument Cluster REFER to Section 413-01 .
B1213 Anti-Theft Number of Programmed Keys is Below Minimum Instrument Cluster REFER to Section 419-01B .
B1231 Longitudinal Acceleration Threshold Exceeded Restraint Control Module (RCM) REFER to Section 501-20B .
B1242 Air Flow Recirculation Door Driver Circuit Failure Dual Automatic Temperature Control (DATC) REFER to Section 412-00 .
B1246 Dim Panel Potentiometer Switch Circuit Failure Instrument Cluster REFER to Section 413-00 .
B1251 Air Temperature Internal Sensor Circuit Open DATC REFER to Section 412-00 .
B1253 Air Temperature Internal Sensor Circuit Short to Ground DATC REFER to Section 412-00 .
B1255 Air Temperature External Sensor Circuit Open DATC REFER to Section 412-00 .
B1257 Air Temperature External Sensor Circuit Short to Ground DATC REFER to Section 412-00 .
B1262 Servo Motor Defrost Circuit Failure DATC REFER to Section 412-00 .
B1263 Servo Motor Vent Circuit Failure DATC REFER to Section 412-00 .
B1264 Servo Motor Floor Circuit Failure DATC REFER to Section 412-00 .
B1265 Servo Motor Cold Air Bypass Circuit Failure DATC REFER to Section 412-00 .
B1299 Power Supply Sensor Circuit Short to Ground Parking Aid Module REFER to Section 413-13 .
B1300 Power Door Lock Circuit Failure REM REFER to Section 501-14 .
B1309 Power Door Lock Circuit Short to Ground Driver Door Module (DDM) REFER to Section 501-14 .
B1310 Power Door Unlock Switch Circuit Failure REM REFER to Section 501-14 .
B1317 Battery Voltage High Instrument Cluster REFER to Section 414-00 .
B1317 Battery Voltage High RCM REFER to Section 414-00 .
B1317 Battery Voltage High Electronic Parking Brake Module REFER to Section 414-00 .
B1318 Battery Voltage Low Instrument Cluster REFER to Section 414-00 .
B1318 Battery Voltage Low RCM REFER to Section 414-00 .
B1318 Battery Voltage Low Electronic Parking Brake Module REFER to Section 414-00 .
B1319 Driver Door Ajar Circuit Failure Front Electronic Module (FEM) REFER to Section 417-02 .
B1327 Passenger Door Ajar Circuit Failure FEM REFER to Section 417-02 .
B1331 Decklid Ajar Rear Door Circuit Failure REM REFER to Section 417-02 .
B1341 Power Door Unlock Circuit Short to Ground DDM REFER to Section 501-14 .
B1342 ECU is Defective Parking Aid Module CLEAR the DTC. REPEAT the parking aid module self-test. If DTC B1342 is retrieved again, INSTALL a new parking aid module. REFER to Section 413-13 . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective FEM CLEAR the DTC. REPEAT the FEM self-test. If DTC B1342 is retrieved again, INSTALL a new FEM. REFER to Front Electronic Module (FEM) in this section. CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective DATC CLEAR the DTC. REPEAT the DATC module self-test. If DTC B1342 is retrieved again, INSTALL a new DATC module. REFER to Section 412-00 . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective Climate Control Seat Module CLEAR the DTC. REPEAT the climate control seat module self-test. If DTC B1342 is retrieved again, INSTALL a new climate control seat module. REFER to Section 501-10 . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective Instrument Cluster CLEAR the DTC. REPEAT the instrument cluster self-test. If DTC B1342 is retrieved again, INSTALL a new instrument cluster. REFER to Section 413-01 . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective Driver Seat Module (DSM) CLEAR the DTC. REPEAT the DSM self-test. If DTC B1342 is retrieved again, INSTALL a new DSM. REFER to Driver Seat Module (DSM) in this section. CLEAR the DTCs. REPEAT the self test.
B1342 ECU is Defective DDM CLEAR the DTC. REPEAT the DDM self-test. If DTC B1342 is retrieved again, INSTALL a new DDM. REFER to Driver Door Module (DDM) in this section. CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective REM CLEAR the DTC. REPEAT the REM self-test. If DTC B1342 is retrieved again, INSTALL a new REM. REFER to Rear Electronic Module (REM) in this section. CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective RCM CLEAR the DTC. REPEAT the RCM self-test. If DTC B1342 is retrieved again, INSTALL a new RCM. REFER to Section 501-20B . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective Anti-lock Brake System (ABS)/Traction Control (TC) Module or Stability Assist Module CLEAR the DTC. REPEAT the ABS/TC module self-test. If DTC B1342 is retrieved again, INSTALL a new ABS/TC module. REFER to Section 206-09 . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU Defective Message Center
NOTE: The message center is part of the instrument cluster.
CLEAR the DTC. REPEAT the self-test. If DTC B1342 is retrieved again, INSTALL a new instrument cluster. REFER to Section 413-01 . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective Navigation System Module CLEAR the DTC. RETRIEVE the DTCs. If DTC B1342 is retrieved again, INSTALL a new navigation system module. REFER to Section 419-07 . CLEAR the DTCs. REPEAT the self-test.
B1342 ECU is Defective Audio Control Module (ACM) CLEAR the DTC. CARRY OUT the ACM on-demand self-test. REMOVE the ACM. REFER to Section 415-00 . SEND the ACM to an authorized Ford audio system repair facility if DTC B1342 is retrieved again. TEST the system for normal operation.
B1342 ECU is Defective Electronic Parking Brake Module CLEAR the DTC. RETRIEVE the DTCs. If DTC B1342 is retrieved again, INSTALL a new electronic parking brake module. REFER to Section 206-05 . CLEAR the DTCs. REPEAT the self-test.
B1352 Ignition Key-in Circuit Failure Instrument Cluster REFER to Section 413-09 .
B1358 Ignition Switch or Blower Electronics Circuit Short to Ground Climate Control Seat Module REFER to Section 501-10 .
B1416 Power Window LR Motor Circuit Short to Battery DDM REFER to Section 501-11 .
B1424 Power Window RR Switch Circuit Short to Battery DDM REFER to Section 501-11 .
B1470 Lamp Headlamp Input Circuit Failure Instrument Cluster REFER to Section 417-01 .
B1479 Low Washer Fluid Level Switch Circuit Failure FEM REFER to Section 413-01 .
B1483 Brake Pedal Input Circuit Failure REM REFER to Section 206-09 .
B1483 Brake Pedal Input Circuit Failure ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B1485 Brake Pedal Input Circuit Battery Short ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B1499 Lamp Turn Signal Left Circuit Failure FEM REFER to Section 417-01 .
B1499 Lamp Turn Signal Left Circuit Failure REM REFER to Section 417-01 .
B1501 Lamp Turn Signal Left Circuit Short to Battery FEM REFER to Section 417-01 .
B1501 Lamp Turn Signal Left Circuit Short to Battery REM REFER to Section 417-01 .
B1503 Lamp Turn Signal Right Circuit Failure FEM REFER to Section 417-01 .
B1503 Lamp Turn Signal Right Circuit Failure REM REFER to Section 417-01 .
B1505 Lamp Turn Signal Right Circuit Short to Battery FEM REFER to Section 417-01 .
B1505 Lamp Turn Signal Right Circuit Short to Battery REM REFER to Section 417-01 .
B1519 Hood Switch Circuit Failure FEM REFER to Section 419-01A .
B1526 Keyless Entry Circuit Short to Ground DDM REFER to Section 501-14 .
B1530 Memory Set Switch Circuit Short to Ground DDM REFER to Section 501-10 .
B1534 Memory 1 Switch Circuit Short to Ground DDM REFER to Section 501-10 .
B1538 Memory 2 Switch Circuit Short to Ground DDM REFER to Section 501-10 .
B1551 Decklid Release Circuit Failure FEM REFER to Section 501-14 .
B1567 Headlamp High-Beam Circuit Failure FEM REFER to Section 417-01 .
B1567 Headlamp High-Beam Circuit Failure Instrument Cluster REFER to Section 417-01 .
B1600 PATS Ignition Key Transponder Signal is Not Received Instrument Cluster REFER to Section 419-01B .
B1601 PATS Received Incorrect Key-code From Ignition Key Transponder Instrument Cluster REFER to Section 419-01B .
B1602 PATS Received Invalid Format of Key-code From Ignition Key Transponder Instrument Cluster REFER to Section 419-01B .
B1627 PRNDL Reverse Input Circuit Failure Parking Aid Module REFER to Section 413-13 .
B1676 Battery Voltage Out of Range FEM REFER to Section 414-00 .
B1676 Battery Voltage Out of Range REM REFER to Section 414-00 .
B1676 Battery Voltage Out of Range Message Center REFER to Section 414-00 .
B1676 Battery Voltage Out of Range DATC REFER to Section 414-00 .
B1676 Battery Voltage Out of Range DSM REFER to Section 414-00 .
B1676 Battery Voltage Out of Range ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B1676 Battery Voltage Out of Range DDM REFER to Section 414-00 .
B1681 PATS Transceiver Module Signal is Not Received Instrument Cluster REFER to Section 419-01B .
B1689 Autolamp Delay Circuit Failure Instrument Cluster REFER to Section 417-01 .
B1703 Seat Driver Recline Forward Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1707 Seat Driver Recline Rearward Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1711 Seat Driver Front Up Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1715 Seat Driver Front Down Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1719 Seat Driver Forward Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1723 Seat Driver Rearward Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1727 Seat Driver Rear Up Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1731 Seat Driver Rear Down Switch Circuit Short to Battery DSM REFER to Section 501-10 .
B1757 Seat Driver Rear Up/Down Circuit Failure DSM REFER to Section 501-10 .
B1761 Seat Driver Front Up/Down Circuit Failure DSM REFER to Section 501-10 .
B1765 Seat Driver Forward/Rearward Circuit Failure DSM REFER to Section 501-10 .
B1769 Seat Driver Recliner F/R Circuit Failure DSM REFER to Section 501-10 .
B1794 Lamp Headlamp Low-Beam Circuit Failure FEM REFER to Section 417-01 .
B1869 Lamp Air Bag Warning Indicator Circuit Open RCM REFER to Section 501-20B .
B1870 Lamp Air Bag Warning Indicator Circuit Short to Battery RCM REFER to Section 501-20B .
B1875 Turn Signal/Hazard Switch Signal Circuit Failure Instrument Cluster REFER to Section 417-01 .
B1891 Air Bag Tone Warning Indicator Circuit Shorted to Battery RCM REFER to Section 501-20B .
B1892 Air Bag Tone Warning Indicator Circuit Failure RCM REFER to Section 501-20B .
B1921 Air Bag Diagnostic Monitor Ground Circuit Open RCM REFER to Section 501-20B .
B1946 Climate Control A/C Post Evaporator Sensor Circuit Failure DATC REFER to Section 412-00 .
B1947 Climate Control A/C Post Evaporator Sensor Circuit Short to Ground DATC REFER to Section 412-00 .
B1966 A/C Post Heater Sensor Circuit Failure DATC REFER to Section 412-00 .
B1967 A/C Post Heater Sensor Circuit Short to Ground DATC REFER to Section 412-00 .
B1984 Luggage Compartment Lid Anti-theft Disarm Circuit Short to Ground REM REFER to Section 419-01A .
B1990 Pedal Forward/Rearward Potentiometer Feedback Circuit Failure FEM REFER to Section 206-00 .
B2078 Driver Airbag Deactivation Indicator Inoperative RCM REFER to Section 501-20B .
B2103 Antenna Not Connected Instrument Cluster REFER to Section 419-01B .
B2103 Antenna Not Connected Navigation System Module REFER to Section 419-07 .
B2112 Door Driver Set Switch Stuck Failure DDM REFER to Section 419-01A .
B2116 Door Driver Reset Switch Stuck Failure DDM REFER to Section 419-01A .
B2139 SCP Not Configured PCM ID Does Not Match Instrument Cluster REFER to Section 419-01B .
B2139 Data Mismatch Navigation System Module REFER to Section 419-07 .
B2141 NVM Configuration Failure Instrument Cluster REFER to Section 419-01B .
B2143 NVM Memory Failure DSM CARRY OUT seat calibration of the DSM. CLEAR the DTCs. REPEAT the self-test. If the DTC resets, INSTALL a new DSM. REFER to Driver Seat Module (DSM) in this section. CARRY OUT seat calibration of the new DSM.
B2143 NVM Memory Failure Instrument Cluster CARRY OUT seat calibration of the instrument cluster. CLEAR the DTCs. REPEAT the self-test. If the DTC resets, INSTALL a new instrument cluster. REFER to Section 413-01 . CARRY OUT seat calibration of the new DSM.
B2146 Seat Recline Motor Position Out of Range DSM REFER to Section 501-10 .
B2149 Seat Front Vertical Motor Position Out of Range DSM REFER to Section 501-10 .
B2152 Seat Rear Vertical Motor Position Out of Range DSM REFER to Section 501-10 .
B2155 Seat Horizontal Motor Position Out of Range DSM REFER to Section 501-10 .
B2158 Seat Recline Motor Memory Position Out of Range DSM REFER to Section 501-10 .
B2161 Seat Front Vertical Motor Memory Position Out of Range DSM REFER to Section 501-10 .
B2162 Data Mismatch No.2 (received data does not match what was expected) Instrument Cluster REFER to Section 413-01 .
B2164 Seat Rear Vertical Motor Memory Position Out of Range DSM REFER to Section 501-10 .
B2167 Seat Horizontal Motor Memory Position Out of Range DSM REFER to Section 501-10 .
B2172 Inertia Switch Input Circuit Open REM REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
B2174 Window Driver Rear Remote Up Switch Short to Battery REM REFER to Section 501-11 .
B2178 Window Driver Rear Remote Down Switch Short to Battery REM REFER to Section 501-11 .
B2190 Window Passenger Rear Remote Up Switch Short to Battery REM REFER to Section 501-11 .
B2194 Window Passenger Rear Remote Down Switch Short to Battery REM REFER to Section 501-11 .
B2204 GPS Antenna Connection Open or Short Navigation System Module REFER to Section 419-07 .
B2208 Navigation to Head Unit Communication Error Navigation System Module REFER to Section 419-07 .
B2243 Driver Rear Door Ajar Circuit Open REM REFER to Section 417-02 .
B2245 Passenger Rear Door Ajar Circuit Open REM REFER to Section 417-02 .
B2290 Occupant Classification System Fault Front Passenger Side RCM REFER to Section 501-20B .
B2292 Restraint System Seatbelt Pretensioner Fault RCM REFER to Section 501-20B .
B2293 Restraint System Airbag Fault RCM REFER to Section 501-20B .
B2294 Restraint System Curtain Fault RCM REFER to Section 501-20B .
B2295 Restraint System Side Airbag Fault RCM REFER to Section 501-20B .
B2296 Restraint System Impact Sensor Fault RCM REFER to Section 501-20B .
B2312 Mirror Passenger Horizontal Sensor Circuit Failure FEM REFER to Section 501-09 .
B2316 Mirror Passenger Vertical Sensor Circuit Failure FEM REFER to Section 501-09 .
B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure DDM REFER to Section 501-09 .
B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure DDM REFER to Section 501-09 .
B2328 Column Reach Feedback Potentiometer Circuit Failure Instrument Cluster REFER to Section 211-04 .
B2332 Column Tilt Feedback Potentiometer Circuit Failure Instrument Cluster REFER to Section 211-04 .
B2336 Mirror Switch Assembly Circuit Failure DDM REFER to Section 501-09 .
B2351 Steering Column Switch Signal Circuit Failure Instrument Cluster REFER to Section 211-04 .
B2358 Adjustable Pedal Switch Failure FEM REFER to Section 206-00 .
B2359 Accessory Delay Output Circuit Failure DDM REFER to Section 501-11 .
B2360 Window Motor Control Output Circuit Failure DDM REFER to Section 501-11 .
B2380 Heater Coolant Temperature Sensor Circuit Short to Ground DATC REFER to Section 412-00 .
B2381 Heater Coolant Temperature Sensor Circuit Open DATC REFER to Section 412-00 .
B2401 Audio Tape Deck Mechanism Fault ACM VERIFY that no tape is inserted in the ACM. CLEAR and DOCUMENT the DTCs. CARRY OUT the ACM on-demand self-test. If DTC B2401 is retrieved again, REMOVE the ACM. REFER to Section 415-01 . SEND the ACM to an authorized Ford audio system repair facility. TEST the system for normal operation.
B2402 Audio CD/DJ Thermal Shutdown Fault ACM REFER to Section 415-00 .
B2403 Audio CD/DJ Internal Fault ACM REFER to Section 415-00 .
B2403 Audio CD/DJ Internal Fault Navigation System Module REFER to Section 419-07 .
B2404 Audio Steering Wheel Switch Circuit Fault ACM REFER to Section 415-00 .
B2404 Audio Steering Wheel Switch Circuit Fault Navigation System Module REFER to Section 419-07 .
B2405 Audio Single-Disc CD Player Thermal Shutdown Fault ACM REFER to Section 415-00 .
B2406 Audio Single-Disc CD Player Internal Fault ACM REFER to Section 415-00 .
B2425 Remote Keyless Entry Rolling Code Out of Synchronization DDM REFER to Section 501-14 .
B2426 Pass Solar Radiation Sensor Circuit Open DATC REFER to Section 412-00 .
B2427 Pass Solar Radiation Sensor Circuit Short to Ground DATC REFER to Section 412-00 .
B2428 A/C Post Heater Sensor No. 2 Circuit Failure DATC REFER to Section 412-00 .
B2429 A/C Post Heater Sensor No. 2 Circuit Short to Ground DATC REFER to Section 412-00 .
B2431 Transponder Programming Failed Instrument Cluster REFER to Section 419-01B .
B2434 Drivers Seat Belt Buckle Switch Circuit Short to Ground RCM REFER to Section 501-20B .
B2435 Drivers Seat Belt Buckle Switch Resistance Out of Range RCM REFER to Section 501-20B .
B2438 Passengers Seat Belt Buckle Switch Circuit Short to Ground RCM REFER to Section 501-20B .
B2439 Passengers Seat Belt Buckle Switch Resistance Out of Range RCM REFER to Section 501-20B .
B2472 Fog Lamp Switch Failure Instrument Cluster REFER to Section 417-01 .
B2477 Module Configuration Failure Electronic Parking Brake Module REFER to Section 418-01 .
B2477 Module Configuration Failure DDM REFER to Section 418-01 .
B2477 Module Configuration Failure ACM REFER to Section 418-01 .
B2477 Module Configuration Failure RCM REFER to Section 418-01 .
B2477 Module Configuration Failure Navigation System Module REFER to Section 418-01 .
B2477 Module Configuration Failure Message Center REFER to Section 418-01 .
B2477 Module Configuration Failure Instrument Cluster REFER to Section 418-01 .
B2477 Module Configuration Failure Stability Assist Module REFER to Section 418-01 .
B2477 Module Configuration Failure DATC REFER to Section 418-01 .
B2477 Module Configuration Failure REM REFER to Section 418-01 .
B2477 Module Configuration Failure ABS/TC Module REFER to Section 418-01 .
B2477 Module Configuration Failure Climate Control Seat Module REFER to Section 418-01 .
B2477 Module Configuration Failure FEM REFER to Section 418-01 .
B2486 Climate Controlled Seat Module Voltage Out of Range Climate Control Seat Module REFER to Section 501-10 .
B2488 Thumb-wheel Switch Voltage Out of Range High Climate Control Seat Module REFER to Section 501-10 .
B2497 Blower RPM Out of Range Climate Control Seat Module REFER to Section 501-10 .
B2521 Tach Circuit Failure Climate Control Seat Module REFER to Section 501-10 .
B2627 Fuel Sender Circuit Open No. 2 Instrument Cluster REFER to Section 413-01 .
B2628 Fuel Sender Circuit Short to Ground No. 2 Instrument Cluster REFER to Section 413-01 .
B2633 Driver Front Microphone Circuit Failure Navigation System Module REFER to Section 419-07 .
B2691 Front Drivers Seat Belt Buckle Switch Circuit Fault RCM REFER to Section 501-20B .
B2692 Front Passengers Seat Belt Buckle Switch Resistance Circuit Fault RCM REFER to Section 501-20B .
B2729 Cushion Over-Temp Detected Climate Control Seat Module REFER to Section 501-10 .
B2730 Back-Over Temp Detected Climate Control Seat Module REFER to Section 501-10 .
B2731 Differential Temperature Fault Climate Control Seat Module REFER to Section 501-10 .
B2734 Pedal Travel Sensor Supply Error ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B2736 Pedal Travel Sensor Circuit Fault ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B2737 Pedal Travel Sensor Jammed Error ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B2738 Pedal Travel Sensor Velocity Error ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B2740 Pedal Travel Sensor Spike Error ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B2741 Sensor Cluster Loop End ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B2792 Heat Switch Short to Ground Climate Control Seat Module REFER to Section 501-10 .
B2793 Cool Switch Short to Ground Climate Control Seat Module REFER to Section 501-10 .
B2795 Driver Solar Radiation Sensor Circuit Short to Ground DATC REFER to Section 412-00 .
B2796 Driver Solar Radiation Sensor Circuit Open DATC REFER to Section 412-00 .
B2797 Driver Water Valve Circuit Open DATC REFER to Section 412-00 .
B2798 Driver Water Valve Circuit Short DATC REFER to Section 412-00 .
B2799 Pass Water Valve Circuit Open DATC REFER to Section 412-00 .
B2800 Pass Water Valve Circuit Short DATC REFER to Section 412-00 .
B2844 Ignition Voltage Out of Range Parking Aid Module REFER to Section 413-13 .
B2858 H/U is Defective Navigation System Module REFER to Section 419-07 .
B2879 Fuel Tank Jet Pump Fault Instrument Cluster REFER to Section 413-01 .
B2900 VIN Mismatch ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
B2913 Audio Sub-Woofer Not Connected Navigation System Module REFER to Section 419-07 .
C1094 Park Brake Apply Switch Circuit Failure Electronic Parking Brake Module REFER to Section 206-00 .
C1095 Hydraulic Pump Motor Circuit Failure ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1132 Clutch Position Circuit Short to Ground Electronic Parking Brake Module REFER to Section 206-05 .
C1133 Clutch Position Circuit Short to Battery Electronic Parking Brake Module REFER to Section 206-05 .
C1134 Gear Shift Position Circuit Short to Ground Electronic Parking Brake Module REFER to Section 206-05 .
C1135 Gear Shift Position Circuit Short to Battery Electronic Parking Brake Module REFER to Section 206-05 .
C1145 Speed Wheel Sensor RF Input Circuit Failure ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1155 Speed Wheel Sensor LF Input Circuit Failure ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1165 Speed Wheel Sensor RR Input Circuit Failure ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1175 Speed Wheel Sensor LR Input Circuit Failure ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1192 Vehicle Speed Circuit Failure Navigation System Module REFER to Section 419-07 .
C1233 Speed Wheel LF Input Signal Missing ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1234 Speed Wheel RF Input Signal Missing ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1235 Speed Wheel RR Input Signal Missing ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1236 Speed Wheel LR Input Signal Missing ABS/TC Module or Stability Assist Module REFER to Section 206-09 .
C1277 Steering Wheel Angle 1 and 2 Circuit Failure Stability Assist Module REFER to Section 206-09 .
C1278 Steering Wheel Angle 1 and 2 Signal Faulted Stability Assist Module REFER to Section 206-09 .
C1279 Yaw Rate Sensor Circuit Failure Stability Assist Module REFER to Section 206-09 .
C1280 Yaw Rate Sensor Signal Fault Stability Assist Module REFER to Section 206-09 .
C1281 Lateral Accelerometer Circuit Failure Stability Assist Module REFER to Section 206-09 .
C1282 Lateral Accelerometer Signal Fault Stability Assist Module REFER to Section 206-09 .
C1284 Oil Pressure Switch Failure FEM REFER to Section 413-01 .
C1285 Booster Solenoid Circuit Failure Stability Assist Module REFER to Section 206-09 .
C1287 Booster Pedal Force Switch Circuit Failure Stability Assist Module REFER to Section 206-09 .
C1288 Pressure Transducer Main/Primary Input Circuit Failure Stability Assist Module REFER to Section 206-09 .
C1408 Parking Brake Release Switch Circuit Out of Range Electronic Parking Brake Module REFER to Section 206-05 .
C1409 Parking Brake Apply Switch Circuit Out of Range Electronic Parking Brake Module REFER to Section 206-05 .
C1414 Incorrect Module Design Level RCM REFER to Section 501-20B .
C1440 Pressure Transducer Main/Primary Signal Faulted Stability Assist Module REFER to Section 206-09 .
C1700 LR Sensor Circuit Failure or Blockage Parking Aid Module REFER to Section 413-13 .
C1703 RR Sensor Circuit Failure or Blockage Parking Aid Module REFER to Section 413-13 .
C1730 Reference Voltage Out of Range (+5 V) Stability Assist Module REFER to Section 206-09 .
C1769 Park Brake Apply Switch Circuit Short to Ground Electronic Parking Brake Module REFER to Section 206-05 .
C1782 Park Brake Release Switch Circuit Failure Electronic Parking Brake Module REFER to Section 206-05 .
C1783 Park Brake Release Switch Circuit Short to Ground Electronic Parking Brake Module REFER to Section 206-05 .
C1784 EBP Motor Output Short to Ground Electronic Parking Brake Module REFER to Section 206-05 .
C1785 EBP Motor Output Open Circuit Electronic Parking Brake Module REFER to Section 206-05 .
C1786 EBP Motor Output Battery Short to Ground Electronic Parking Brake Module REFER to Section 206-05 .
C1799 Hall Effect Circuit Failure Electronic Parking Brake Module REFER to Section 206-05 .
C1801 Motor Engage Current Reached Before Full Apply Travel Distance Electronic Parking Brake Module REFER to Section 206-05 .
C1802 Motor Engage Current Not Reached or Traveled Too Far Upon Apply Electronic Parking Brake Module REFER to Section 206-05 .
C1803 Motor Disengage Full Travel Distance Not Reached Upon Release Electronic Parking Brake Module REFER to Section 206-05 .
C1805 Mismatched PCM and/or Stability Assist Module Stability Assist Module CHECK for correct component and configuration for the PCM and stability assist module. INSTALL a new stability assist module as necessary. REFER to Section 206-09 . CLEAR the DTC. REPEAT the self-test.
C1924 VAPS Solenoid Actuator Output Circuit Short to Ground FEM REFER to Section 211-00 .
C1925 VAPS Solenoid Actuator Return Circuit Failure FEM REFER to Section 211-00 .
C1947 Seat Track Position Switch Circuit Short to Ground RCM REFER to Section 501-20B .
C1948 Seat Track Position Switch Circuit Resistance Out of Range RCM REFER to Section 501-20B .
C1963 Stability Control Inhibit Warning Stability Assist Module REFER to Section 206-09 .
C1969 TC/YC Switch Lamp Circuit Fault Stability Assist Module REFER to Section 206-09 .
C1981 Front Drivers Seat Track Position Switch Circuit Fault RCM REFER to Section 501-20B .
C1983 Radar Sensor Fault Parking Aid Module REFER to Section 413-13 .
C1984 Radar Sensor Circuit Failure Parking Aid Module REFER to Section 413-13 .
C1985 Back Up Aid Disable Switch Stuck Low Parking Aid Module REFER to Section 413-13 .
C1987 Yellow Fault Warning Lamp Indicator Short to Battery Electronic Parking Brake Module REFER to Section 206-05 .
C1988 Yellow Fault Warning Lamp Indicator Circuit Failure Electronic Parking Brake Module REFER to Section 206-05 .
C1989 Park Brake Apply and Release Switch Contacts Energized Simultaneously Electronic Parking Brake Module REFER to Section 206-05 .
C1991 Module Calibration Failure Stability Assist Module REFER to Section 206-09 .
C1992 Vehicle Speed Circuit Failure Parking Aid Module REFER to Section 413-13 .
C1996 Active Yaw Control Disabled Stability Assist Module REFER to Section 206-09 .
C1998 Module Calibration Not Complete Stability Assist Module REFER to Section 206-09 .
C2777 Sensor Cluster Bus Failure Stability Assist Module REFER to Section 206-09 .
C2778 Sensor Power Supply Failure Stability Assist Module REFER to Section 206-09 .
C2790 LED Array Circuit Failure Parking Aid Module REFER to Section 413-13 .
U1009 SCP (J1850) Invalid or Missing Data for Engine Torque ABS/TC Module or Stability Assist Module REFER to Section 418-00 .
U1016 SCP Invalid DATA (PCM) Navigation System Module REFER to Section 419-07 .
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM Electronic Parking Brake Module REFER to Section 418-00 .
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM PCM REFER to Section 418-00 .
U1027 SCP (J1850) Bus Invalid or Missing Data for Engine RPM ABS/TC Module or Stability Assist Module REFER to Section 418-00 .
U1027 SCP (J1850) Bus Invalid or Missing Data for Engine RPM FEM REFER to Section 418-00 .
U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed Electronic Parking Brake Module REFER to Section 418-00 .
U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed FEM REFER to Section 418-00 .
U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed REM REFER to Section 418-00 .
U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed DDM REFER to Section 418-00 .
U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed Instrument Cluster REFER to Section 418-00 .
U1051 SCP (J1850) Invalid or Missing Data for Brakes Electronic Parking Brake Module REFER to Section 418-00 .
U1053 SCP (J1850) Invalid or Missing Data for Steering/ Steering Wheel PCM REFER to Section 418-00 .
U1058 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/ PRNDL Electronic Parking Brake Module REFER to Section 418-00 .
U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/ PRNDL PCM REFER to Section 418-00 .
U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/ PRNDL ABS/TC Module or Stability Assist Module REFER to Section 418-00 .
U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/ PRNDL FEM REFER to Section 418-00 .
U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/ PRNDL REM REFER to Section 418-00 .
U1059 SCP (J1850) Invalid or Missing Data for Transmission/Transaxle/ PRNDL DDM REFER to Section 418-00 .
U1073 SCP (J1850) Invalid Or Missing Data for Engine Coolant ABS/TC Module or Stability Assist Module REFER to Section 418-00 .
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant PCM REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant Instrument Cluster REFER to Section 413-01 .
U1083 SCP (J1850) Invalid or Missing Data for Engine Systems Other PCM REFER to Section 418-00 .
U1098 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control PCM REFER to Section 418-00 .
U1123 SCP (J1850) Invalid or Missing Data for Odometer Instrument Cluster REFER to Section 418-00 .
U1123 SCP (J1850) Invalid or Missing Data for Odometer Message Center REFER to Section 418-00 .
U1134 SCP (J1850) Invalid or Missing Data Ignition Switch/Starter Electronic Parking Brake Module REFER to Section 418-00 .
U1136 SCP (J1850) Invalid or Missing Data for Telltales PCM REFER to Section 418-00 .
U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security System ABS/TC Module or Stability Assist Module REFER to Section 418-00 .
U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security System PCM, Instrument Cluster REFER to Section 418-00 .
U1218 SCP (J1850) Invalid or Missing Data for External Lamps FEM, REM REFER to Section 418-00 .
U1222 SCP (J1850) Invalid or Missing Data for Interior Lamps FEM REFER to Section 418-00 .
U1243 SCP (J1850) Invalid or Missing Data for Exterior Environment PCM REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
U1262 SCP (J1850) Communication Bus Fault Electronic Parking Brake Module REFER to Section 418-00 .
U1262 SCP (J1850) Communication Bus Fault Network Fault REFER to Section 418-00 .
U1262 SCP (J1850) Communication Bus Fault Instrument Cluster REFER to Section 418-00 .
U1262 SCP (J1850) Communication Bus Fault ABS/TC Module Or Stability Assist Module REFER to Section 418-00 .
U1262 SCP (J1850) Communication Bus Fault Message Center REFER to Section 418-00 .
U1430 SCP (J1850) Invalid Data for Function Read Fuel System Message Center REFER to Section 418-00 .
U1751 SCP (J1850) SCLM System Status Missing From REM Instrument Cluster REFER to Section 418-00 .
U1752 SCP (J1850) SCLM System Status Missing From FEM Instrument Cluster REFER to Section 418-00 .
U1901 CAN Network #2 Communication BUS Fault Receive Error ABS/TC Module or Stability Assist Module REFER to Section 418-00 .
U1950 UBP Communication Bus Fault Parking Aid Module REFER to Section 418-00 .
U2306 Transmission PRNDL Range Selected Status Invalid Parking Aid Module REFER to Section 413-13 .
U2150 SCP (J1850) Invalid Data From REM Instrument Cluster REFER to Section 418-00 .
U2152 SCP (J1850) Invalid Data From FEM Instrument Cluster REFER to Section 418-00 .
U2195 REM (J1850) Invalid DATA From SCLM Instrument Cluster REFER to Section 418-00 .
U2362 UBP Invalid Data From Node ID $98 Climate Control Seat Module REFER to Section 501-10 .
http://deneau.info/ls/s6x~us~en~file=s6xja003.htm~gen~ref.htm
http://deneau.info/ls/s6x~us~en~file=s6x71019.htm~gen~ref.htm
What about codes above p1900? I got codes about my cats, P2196 and p2198.
Thats a great site!!!!!!!! You just punch in the code and it comes up without having to scroll down a million pages. I lost the link to a OBDII code website I had. Been trying to look for it but I get these bad ones. Thanks joe.
