Just in case you are serious...
Gen I have traditional, direct throttle control. A mechanical cable links the gas pedal and the throttle together. Movement of the gas pedal always causes the same movement of the throttle.
Gen II has Electronic Throttle Control, or throttle by [electrical] wire. The gas pedal is connected only to an electronic potentiometer (two actually). This tells the computer what position you are holding the gas pedal at. The actual throttle on the engine is then controlled by an electric motor that is controlled by the computer. When you press on the gas pedal, the computer decides the best combination of transmission gear and throttle position to give you the power you are requesting. Why do this? Well, you eliminate the possibility of a stuck throttle cable, you no longer need an IAC (just use the throttle to control idle), the rev limiter no longer has to cut fuel to limit revs, and so on. Of course, the real reason is that it enables computer strategies that increase gas mileage. That's why almost all cars made now have ETC.
