Fog lights??
josh01LS
West Bend
I was running a set of Nokya hyper yellow H10 fog lights for about three months and the right side burned out. So I hopped online and ordered a new set from Ken. As I was replacing the bulbs, the clip on the right side was broken but not completely off. I took out the bulb and there was a little bit of water between the plug and the bulb. I took out the other side and there was a lot of water between theclip and the bulb but, it wasn't burned out. What gives?? How does water get in there? Anyways today after leaving the local watering hole the right side burned out again?? Does anyone have a clue as to what is happening??
Sounds like the seal around the connector is bad. You may want to replace those so that water doesn't get in between the connections.
