Fog Light Wiring?
MDLSV8
Upper Marlboro, MD
Fog light went out on my 00 LS. Went to replace, noticed water came out of the plug and saw some corrosion. Can I just clean the connector or do I have to replace the wiring? Is it a harness?
I had the same exact problem with mine. I bought a pair of the Nokya heavy duty wiring harnesses from Ken @ LSKoncepts. I went to cut the old harnesses off and noticed that the ground wire showed signs of arcing. I spliced on the new harness and it works just fine. I just can't believe how thin the gauge is on the foglight wires compared to the headlight wires.
