chocolat1701
during the last 6 months i have replaced all the cooling components of my 04 v8, this is what i have replaced upper and lower radiator hose, radiator,water pump,degas bottle, thermestat housing, thermestat, thermestat cover, thermestat housing neck (this goes to the engine), the dccv was replaced over 2 years ago and now the car is not leaking we did a preasure test and its holding, i bleeded the system several times and the fan turns on and blowes hard but the temp gauge does not go up, if i turn on the heat to 90 the fan stops and all is normal and the heat comes out hot. if i turn on the ac and set it to 75 it the fan gradually turns on and goes to high, we checking it with a scan tool and the engine temp goes to 228 and when we turn on the heat it goes down to 218/220. now we also was scanning with the ac on and driving in highway speed and the temp went down to normal and fan turned off. also after checking the lower hose is cool to the touch and the upper is hot. i think we checked eaverything and cant find the issue. the only thing i can think of is that i added prestone stop leak and it maybe clogging something up. now i was thinking if the dccv is clogged will this couse this its the only thing that i can think off. NEED HELP
