Factory sub amp has turn-on pop
jaweis
colorado springs
I just finished installing my eclipse 5435 head unit, turned out great. I used the proper wiring harness adaptor and everything plays fine, but it has a terrible amp turn on pop as soon as I turn the key on, any ideas how to make this go away? Also, did the factory alpine cd player have a crossover in it for that sub amp? I ask because the eclipse rca's plug into the it but the woofers now sound as if they are playing full range.
you can use a resistor also. drop down the voltage to 9 volts or so. either way would work. as far as the cross over issue im not sure on that with out listening to it. i dont have the rear subs in my car. im sure somebody has had and fixed that problem. good luck.
