Expert LS guys needed
brooke
windom minnesota
Alright....I had a code for engine fall cuz i was just tooling around town for coil three. Went to gas station one night didn't hardly want to start. Got home and parked it. Went to leave next day nothing. I completely forgot about the fall safe DTC and assumed the starter finally went out. I had one on have as it seemed to have a flat spot in it for at least a year. Kinda why I assumed it to be that. Went about the hellish job of swapping starters... After a few days and numerous curse words and different 13 mm tools borrowed from friends it finally was accomplished lol. Before I tried it tho I went to clear codes. Clamped the positive and negative wires together for a few hours came back and hooked battery up and charged... Nothing. Dash came on security light blinking fast. Went and got a new battery. Still nothing.. Had a friend climb under and monkey with starter he broke one of the studded posts on the Solonoid,FML!!!I decided screw it I'm not taking that starter back off and grabbed the Solonoid off the old one. Ta da! Nope... Before it would at least crank. It would crank till the computer shut it off, which is odd cuz I figured it cranked until battery was dead. But now nothing. No dash light except air bag radio does work and function got done light a no PATS light any more on the dash. Unless I have it locked over night then it flashes until I unlock and get in car... Checked power every where and continuity. My last job I was a mechanic so I'm not your typical female guys. Pushed the enertia fuel shut off. Only thing that seems off,I pulled the diode under the hood fuse box and it says open loop instead of continuity... Any help would be greatly appreciated!
What all codes did you have when you went to clear them? I am not a first Gen LS owner i own a 06 LS but i will try to help. Also you should check you're fuses and relays since you're friend broke one of the studs off the solenoid he could have blown something if the battery was hooked up. And if you didn't remove the starter to replace the solenoid its possible your wires are not hooked up correctly.
The last codes before the dtc wasn't working anymore was it was putting it in fail safe mode due to a coil pack being bad I've replaced coil pack
Try to disconnect the battery cables again if it still doesn't crank over you might have a PATs code which will prevent you from getting it started, Forscan might help here but you must find out what PATs code you have when the light on dash blinks sorry this is a really short answer to a long diagnostic problem, check the starter fuse and relay also
@AmsterDutch no way really?! Small world!! Will if you are ever bored and get my direction she's still down for the count... I've got the service manual gonna run down some of the trouble tree tonight hopefully narrow it down. Haven't drove her since Sept
Little disappointed thought this forum rocked a few years ago....
Im sorry you haven't got you're car going. But you haven't updated us on what you've tried or haven't tried. Its hard to fix your Lincoln over the internet without knowing whats been done to it up to this point. LVC is full of people willing to help but you gotta do you're part and let us know whats been done. Have you checked you're relays? How about all electrical connectors for broken wiring? Do you have spark? Maybe you're coil is bad. Are you gettinng fuel to the fuel filter? These cars are sensitive and just because it seems like this part is bad it really could be something else causing it to appear that way. The only way we are gonna narrow you're problem down is to start checking things off and going from there.
