Markviiiedrea
Speed Bump
A while back my spark plug blew out of the head, so I Heli-coiled it back in and it lasted 10,000 miles or so. Well it popped again and once I started looking into it, changing out the motor was the best option, not to mention I got the new 04 motor for $185 w/147,000 on it.
The dealer told me it would be between $200-$300 to fix the threads and I would still be left with my other two ongoing issues. I have a bad idle when cold that I have been chasing for two years and wanted to update the intake before it cracked. This motor has the new intake and is a PI engine so hopefully has a 20HP bump (we all could use a little more in these cars)
So last night I bought a bunch of gaskets to replace while the engine is out and easy to get to. The following I have and will be doing, if you see anything that I should just avoid or something missing let me know.
-Oil pan gasket
-Oil filter adapter gasket
-Rear main seal
-Valve cover gasket
-T-stat and gasket
-Throttle body gasket
-Water pump gasket
-Exhaust manifolds and flange gaskets
-Autolite platinum spark plugs and some anti-seize
-Engine degreaser
-New coolant and 6qts of 10w30castrol oil w/Napa silver oil filter
-Block heater (600W)
If you can think of anything else I should be doing while the engine is out let me know?
-Oil pan gasket
-Rear main seal
-Valve cover gasket
-T-stat and gasket
-Water pump gasket
-Engine degreaser
