Our LS has done this a few times to us at stoplights and then starts right back up. My wife gets really nervous though when it happens at nighttime with our baby.
This happened before with my T-bird Supercoupe which turned out to be the DIS module. If I remember right there was one that controlled it at start ups and one that controlled it running? Then our Mazda 626 would do this and it turned out to be the distributor.
Do you think these could be the issue(s) on our 00 V6 LS?
Thanks[/QUOTE
I found the answer. My Lincoln was shutting off at every light, and stop sign.
Take off the manifold
Take off the gaskets ( NEED TO REPLACE)
Take off the injectore housing (DO not remove injecters)
Take off the gaskets under the injecter housing ( Need to replace)
Under all this is in the middle of the block is a little box that has a 3 inch rubber hose conected to a steel hose that is connected and runs to the throttle body. Under that 3 inch rubber hose you'll find a big hole, replace that rubber hose. Also replace the hose that runs from the steel pipe to the throttle body.
Dont try taking the box out because you cant just replace the hose.
