ramairmustang
Okay when I first got my Mark the engine light would come on at highway speeds then go out when speeds would drop below 45mph. I took it to the shop to see if they could get a code from the OBD-I and I was told that I need to replace the O2 sensors. Well I did that last week when I got my Borla's put on and everything was good for a couple days now when drove hard say accelerating quickly at highway speeds to pass that butt hole who speeds up when your light comes on to get over. 55 - 90 the light will come on and stay on till again speeds drop to below 45mph and then sometimes it wont turn off untill the car is stopped for a bit at a red light or turned off and back on. I dont really have the money to keep taking it into the shop when it doesn't do it all the time. I figured someone on here could tell me how to check an OBD-I computer myself while driving to catch a code cause that's when it comes on or does it store itself somewhere. I replaced the O2's with NGK's as that's all I could afford. I also noticed that after replacing the O2's if I floor the car from a stop I no longer burn rubber all through 1st gear with the switch chip activated but only get what I alway's have got with factory program. If that helps anyone out. Sorry im rambling.
