GWL
I have had an annoying gremlin in my 04 LSE since it was new. Occasionally, the battery will go low and the car will not start until it is jumped. It would not be a problem, except that it causes the "Service Parking Brake" light to go on and it cannot be reset by the usual battery disconnect procedure. this light must be reset at the dealer. This has happened perhaps 4 or 5 times since new, with no apparent pattern. The battery tests OK, the Alternator & voltage regulator tests OK and the dealer even kept the car for 2 days testing for an unknown draw with no success. The computer indicated "low voltage" as the only indication that there had been a problem when it occurs. One additional symptom when the no start condition happens is the headlights flash and the horn sounds when the key is turned to the start position. Again, no warning, no low interior lights to give a clue that the battery is low. Factory engineers have not responded with a fix to the local tech's inquiries about this problem.
