mharrison said:
DLS8K
Do you have any tips for cleaning your car with a Clay Bar? Mine has some overspray speckles on it. Any clay bar better than others?
Any clay bar will work just fine....stay away from the heavy duty stuff though as it is too abrasive for many applications. As for the tips on how to clay bar, I'll list how i always did it.
1-wash the car
2-use a oil and tar remover of some sort and remove any heavy areas you may find on the lower half of your car. Then wipe that off with some water and a rag so the clay bar will work well.
3-take a spray bottle of gloss enhancer or even a bottle filled with soapy water and spray a section.........like half the hood, or a door, or the trunk.
4-use the clay bar in back and forth motions using a firm but not too heavy pressure. Make sure the paint has pleanty of lubrication on it and mead the clay bar often to prevent scratching the paint with built up contaminents.
5-Wipe the area you just did with a wet chamois and proceed to the next area.
6-DO ALL OF THIS IN THE SHADE OR IN A GARAGE.
Keep in mind, after you do this, you will have no wax left on your car. So, you should then polish the paint (by hand or random orbital buffer) and then wax it with a carnuba wax (several times). From there, wax your car after you wash it a few times.....the more you wash, the more you wax. If you do it right and maintain the surface, you shouldn't have to clay bar the car for quite some time. I did my Lincoln LS once with the clay bar/polish and kept up on waxing and my paint was smooth 15 months later as it was the day I first detailed it. Hope this helps......don't hesitate to ask if you need anymore help.
