elecric glitch?
how did you check the bulbs?
also, the running lights in the trunk?
check the wiring harness in the trunk that moves around a lot.
Sounds like a multifunction switch failure to me. My Gen 1 had the same issues the day I bought it. Did not even know until I drove into my service garage and one of my guys told me I had no brake lights. I also had a bad trunk harness. The dealer replaced the trunk harness and then had to do the column switch.
Along the left hinge. You will probably have to cut into the outer covering to check the wires.
the only lights thst come on are headlights, no sidemarkers, license plate , tailights. highbeams, brake, directional,haz, ok? im dyin' ova here!
