footballcoach
After seeing this warning message (EFC Engine Failsafe Mode) in my 2003 Lincoln LS 3.9, I changed the cheaper part the code reader identified: "Throttle Actuator Control System - Forced Limited Power". After I changed it the same warning message appeared. The code reader still indicated the more expensive part "Throttle Actuator Control Motor Circuit" ($700) needed replaced. I replaced it. Same warning message. The code reader also said the Throttle Actuator Control System - Forced Limited RPM was a problem but I hoped changing the other two parts would solve this problem.
In what I think is an unrelated issue, the parking brake will not release. This issue occurs when I back up out of my driveway; but not very often. I know the parking brake is on only b/c the parking brake light is on, on the console and the message center says, "Release brake", or something to that effect. It is not noticeable when I drive the car but the brake-warning lights in the back of the car are on, too. When the Failsafe Mode message came on in the past this issue also existed simultaneously. In the past, I'd go out later and start the car and there were no issues for a long, long time. Now it seems like the issue is going to persist. Any ideas?
