Ebay Auction: Want to know how bad it will be to use this spacer/hub size modifier?
no, it will be bad. because these spacers/adapters will subtract about 31mm from the wheels offset.
so if you going to run a 31mm offset wheel, your effective offset is now 0. and that's not gonna work.
so either you will need to find 60mm offset wheels, or go another route. (hub swap!)
ok thanks just wanted to check into it.. im not familiar with the offsets for the car, and this sounded like it night be what i needed..
Thanks for quick reply.
In laymans terms wheels that are normal fit to our cars will now stick out 1 1/4 inches!!
