easiest way to remove the v8 head
Lincoln LS
  1. kevinfish
    kevinfish New LVC Member
    4
    Jan 23, 2019
    California
    Hi everyone:
    The Lincoln LS shop manual says to remove the engine first. Video's I've seen online make it appear you have to at least remove the radiator, balancer, and front cover. I'm wondering if anyone has just removed the intake, exhaust, marking the main timing chain to its cam sprocket with some paint, then lowering it down with some bailing wire tied to it, then just pulling the head by itself.
    Will that work or is there something that's going to make doing it this way impossible?
    TIA,
    -Kevin
  2. joegr
    joegr Dedicated LVC Member
    19,904
    1,499
    Dec 10, 2005
    Gulfport
    Why are you pulling the head? If it's for a cooling problem, you are 95% likely to be looking in the wrong place.
    That said, You can't remove the head without removing the timing cover first.
  3. kevinfish
    4
    Jan 23, 2019
    California
    Bent valve. Does the front cover physically obstruct the head from being removed? From watching a video it just looks like there might be a bolt or two going down into it but that's all
  4. joegr
    19,904
    1,499
    Dec 10, 2005
    Gulfport
    I'm not sure. There is a dowel pin or two on the cover. Seems like you'll need to remove it to change the chains anyway. I think that you can get the cover off with the engine still in the car.
    Most of the short cuts that I have tried to do stuff, ended up taking longer and being more difficult than just following the correct procedure.
  5. kevinfish
    4
    Jan 23, 2019
    California
    I can appreciate that. I'm gonna give it a stab anyway, as it's already along the critical path to doing it the recommended way.
  6. kevinfish
    4
    Jan 23, 2019
    California
    Also, I'm not changing the chains. Do you know if there are any dowels on the block deck? I think they would be more likely to stop me than any pins on the front cover. The video I was watching didn't appear to have any dowels on the front cover nor on the deck (but I'd find it kind of hard to believe that since aligning them would be a bitch).
    (link to the part where the front cover comes off -- watch at .25 speed to get the best view):
    (link to the part showing the decks)
  7. 04_Sport_LS
    04_Sport_LS Dedicated LVC Member
    3,145
    347
    Jun 12, 2012
    Somewhere around Lake Erie
    I don't recall seeing an engine in the last 40 years that didn't have dowels in the deck.
    And you're not gonna replace the chains, (and phasers and tensioners)???
    Think you're probably gonna be replacing a piston, (and rod, and bearings), too.
  8. 04_Sport_LS
    3,145
    347
    Jun 12, 2012
    You were warned.
  9. 04_Sport_LS
    3,145
    347
    Jun 12, 2012
    Have fun with that. The cams are most likely going to move on you.
Share This Page
