Drive shaft
they just put a 97 in the lkq yard in your area a few weeks ago. it might still be there with a shaft in it for the cheap. a 93 shaft depending on if its an early 93 is better in the sense that its a 1 piece shaft. really it translates to less vibrations at higher rpms. its mostly only needed/wanted if you are doing 4:10 gears or bigger. with gearing less then that you might not really notice any kind of difference.
thanks I try in the morning. I don't have 4:10 s but I have over 450 horse power 3:73 s
