DPFE Hose replacement help 01V6
tireman
atlanta
Going to change out my DPFE hoses on the old 01V6. The problem is there is no room to work between the engine and firewall to replace the two hoses. Has anyone changed them on the 01V6 that can instruct me on how to do it? thanks tireman 01V6 222K miles running well.
Hey there, you need to remove the wipers, cowl and 3 point brace to make access.
That's what I thought, if i had skinnier arms i could slip in behind the brace. Ok, i'll have a go at it. Best Regards Tireman
Yeah, you really want to get a good access to that area, it's literally the only way to see what you are working on.
