I installed a double din headunit today..Just curious if most of you that have done this tapped the factory metal bracket to line up with the headunit or, used the plastic brackets that were included in Metra kit?
Reason i'm asking is the plastic brackets seem flimsy and cheap..The last question is how did you secure the rear side of the headunit to the vehicle? I just wanna make sure it's in the dash as securely as possible..
This was a fairly easy install just wanna make sure it's done right I'm going to be installing the steering wheel control kit tomorrow cause it got dark on me and since i have it apart again thats the time to fix things...
Thanks in advance
LSinBmore
Thanks in advance
LSinBmore
