theophile
In summer 2012 I bought several bottles of Motul DOT 5.1 brake fluid that I intended to put into a Honda Odyssey. I ended up letting a shop do the brake flush so I still have these bottles of brake fluid, which have never been opened.
Now I'm overhauling the suspension on the LS, and I have noticed that my brake calipers and brackets look quite unappealing, with some surface rust and other discoloration. I'm considering cleaning them up and painting them, which I would prefer to do off the car so I don't have to worry about overspray and so I can keep working on the suspension at the same time. As removing the calipers would likely result in at least some fluid loss, I'm wondering if it's worth doing a DIY brake flush and fill with the DOT 5.1 I've had for 3 years.
So that leads me to my questions:
1. Is it OK to use DOT 5.1 in these cars? My understanding is it should be OK because DOT 5.1 is glycol-based and can be mixed with DOT 4 and/or DOT 3.
2. If I do this, my plan would be to disconnect the brake lines at the caliper and just let them drip into a container, and then when I put the calipers back on, top off the master cylinder with the new DOT 5.1 and then use my Mityvac to bleed each line with the bleeder valve (making sure to keep the master cylinder topped off) until I see the new fluid coming out of the bleeder. Is this the right way to do it?
