I have a starting issue that just started today. The car started great this morning.
When I was leaving work. I tried starting it, and I could her the starter clicking. Then after 5 tries it started to turn over but only for a second then it would stop. As if the battery was dead. Once I took the key out of the start position the alarm would start going off.
So I would hit unlock on the keyfob. Lock, unlock and retry and the same thing would happen. After 20 tries or so It would almost start, but the starter would stop cranking right before it got going or I think the car might shut down, as it was starting. Then the alarm would go off.
Then it starts.
I drive home.
starts fine 5 more times in a row.
Go out late at night same problem again about 8-10 minutes of screwing around to get it going again.
Could it be alarm problems, relay or my new starter is a faulty one?
Then it starts.
I drive home.
