Replace the motor mounts? How difficult and where should I buy them? What's the advantage of solid or hydraulic?
The car still has the original motor mounts and I do know they are old. There is some visibly noticeable movement in the engine when you apply the throttle.
At what point do you need to replace the motor mounts. What other symptoms. I've heard a klunk or click sound when I simultaneously brake and turn in parking lots or at low speed and I can't identify the source. Almost every suspension component has been replaced. Could this sound be the result of a motor mount.
Second question, is anyone familiar with what'll be involved? Can I switch the mounts (2 I think) reasonably easily in the driveway? Is it just a matter of putting a jack under the engine and removing one side at a time? Has anyone done this on a Mark VIII or 89+ Thunderbird/Cougar V8?
Last question, what kind I get. Solid rubber? Factory?
