I have drained and refilled coolant system the following procedure and also replaced thermostat (Drilled a small hole in the edge of the thermostat) around the 20.000miles from now on. I’ve never hand any issue during the time. Recently, I’ve got a low coolant message in the computer every morning. When I opened hood, engine coolant level is lower than normal level in the reservoir.
Then, I just reset the computer and I drove the car without refilling a month. I’ve never gotten any issues. engine temperature gauge stays in the middle of the “NORMAL” range and the lower radiator hose should feel hot to the touch. No overheating, No leak. I think, after the car run, the reservoir level became normal position.
But I just getting more often “low coolant message” in the morning and engine coolant level is getting low than in the beginning of issue.
Is my coolant system air traps? Or It just a normal? Do I have to do air burping or just refill the coolant the recommend procedure?
Thanks,
Thanks,
