DIY Lower Foot Well Vanity Light Replacement '98-02 Lincoln Continental
Svets96
North East Ohio
For those of you who have bulbs burned out it's quit simple to replace majority of the time. Sometimes it may look like it may be a real PITA, but when you look closer its really simple. To replace the lower vanity light in the drivers side foot well area all you have to do is pull the bulb out and push the new one in!!
Replacement part # from Autozone is Sylvania 161LL.
Only costs $5.00
**Make sure you take a clean cloth and wipe off your finger prints on the new bulb. Just in case so that it doesn't burn out prematurely. I do this as an extra step.
1. First locate on drivers side the bulb and bulb socket. Its located just above the e-brake behind the black plastic cover:
2. Next pull out the old bulb out of socket:
3. Push new bulb in, and wipe off grease from fingers with a clean cloth:
DIY procedure is complete for the drivers side, the passenger side is pretty much the same.
