Differential and gear help PLEASE.
APS
Shakopee
I've come to the conclusion that the clutches in my diff are shot.
Ohhhh and my tires are bald after entering a burn out contest. :shifty:
Any recommendations on what diff to run, also checking with you guys to
see what gears you've been running in your LS. Mine is a 2002 3.9 with a auto.
Not really looking to spend the big $$$$ till Im finish fabbing up my turbo kit.
I own a speed shop, have lots of experience with Mustangs ....
not sure if they're the same center section as the Cobra....? don't think so.
Someone told me they were a 8". Haven't even had a chance to look at it yet.
INPUT WOULD HELP!
Thanks guys
Shakopee, MN? I'm in Grand Rapids, MN.
Yes, 8.0" rear end. 8.8 pumpkin is needed to gear up. With the 8.8" pumpkin comes the added work of custom fabbed brackets and a custom driveshaft.
A 8.8" 28 spline LSD carrier will fit into the stock 8.0" pumpkin, as long as you reuse your stock ring gear and pinion. That's what I'm running. Mustang LSD carrier (I believe it was from an 05 GT) into the LS stock 8.0" pumpkin.
so there is no one that make a set of gears for the 8"?
Not that I've been able to locate. Or anyone else for that matter.I suppose you could have them made, but that's quite a bit more expensive.
Hey can you PM your phone # so we can chat?
i dont trust speed shop owners like you for a second...maybe thats because the last backyard mechanic who opened a shop wasted 4,000$ of mine.
If you cant figure it out...well....
Maybe you need to be smart enough to do a little more research dumbass.
Don't come on here and bash me behind your f'en keyboard.
....besides I don't think this pertains to you. Get life.
Let see you build a 750hp turbo car and get invited to King of the Street? NO!
Guys like you are a waste of skin. Did I come on here and attach you for no reason? NO. F off....I work hard for my money.
i.ll shoot you a pm in the morning apc. Don.t know how much help i can be, as the ls is the first car i.ve been interested in learning about.
