LSC_YA
I just replaced thermostat after a over heat the other day. Bleed system and stayed cool, but coolant keep getting low. I looked under car and good stream dripping behind left front tire. Thinking degas bottle leaking, just replaced a couple a years ago they crack that soon. What is your thoughts.....Also had a no or low heat problem the last few days, seem to get worse over time, from getting heat after running temp up and down to no heat. I realize low coolant will cause it, just wondering if DCCV could be causing or related to other. thanks
