1CleanLs
Let me start off by saying that I am no mechanic but I think I found a way to diagnose a bad DCCV. After replacing ac fuse several times and fuses blowing as soon as I put them in I decided to try something I used to do when I had hydraulics on my lowrider many years ago. As some of you know, hydraulic pumps get activated by solenoids and since the dccv is a solenoid I decided to do this test. All I did was tap the dccv with a long screw driver several times and after putting a new fuse I have full ac now! Fuse has not blown which leads me to believe that the issue with my ac blowing hot and blowing fuses is indeed due a the solenoids on the dccv getting stuck from time to time. I will be ordering a new obe soon, but at least I have confirmed that its indeed the dccv that is giving me issues and not the ac clutch or ac display/control panel. I hope this info helps some of you with this very commom issue. Thanks
