My info helped! Sweet. I couldn't find diddly squat on this issue but I knew there'd eventually be someone out there who could use the info. When I was trying to google out this prob, I found many issues with the dccv, but nothing about this evap discharge sensor. Believe it or not, I still haven't replaced mine- I left it unplugged and it's still working great. I do need to pick one up though, it's on my list. I've done all the coils (Visteon), fuel filter, valve cover gaskets, pcv valve. My next project is to replace the slightly leaking water pump, serpentine belt, and this stupid plastic coolant pipe that runs across the motor and connects several other coolant hoses and thermostat together. I ended up breaking the little coolant nipple off the main plastic pipe. If anyone needs only this part DONT ORDER THE ~$200 ONE! I found just the plastic pipe w/ the upper hose for like ~$70 on Amazon, and it's Motorcraft.
