Dash trim kit?
jacquezzz
Iowa
Does anyone know of a trim kit that will cover all of the existing factory wood trim on my '02 LS including all of the door trim pieces? I would just paint them but I really want the aluminum look. Thanks for any help.
No one makes a kit to cover the existing wood in the LS. If you wanted to convert to the aluminum look do a google search on brushed aluminum vinyl. You can cover the existing wood like I did. I covered it with simulated carbon fiber vinyl. It wasn't hard just time consuming.
I worked with the dash kit manufacturer I use and they just recommend getting the factory navigation piece they sell for the 03-06 LS's. At this time they have not talked about selling it individually yet.
so if i order the 2001 dash kit and put down the navigation option, those pieces will fit around my double din? or does it have to be 03-06...
The navigation piece for the 03-06 LS's should fit around the double DIN units. If you ordered just select the navigation option and None for the Audio. I'll have them include the navi piece instead of the radio piece.
