Cylinder 4 Misfire
zzpw3x
Pittsburgh
I have an 0304 (cylinder 4 misfire) and a 0352 (Ign Coil B).
Question is, where the heck is cylinder 4 / Ign Coil B?
I've searched and now I give up.
Thanks for the help.
Dale
First, the question is do you have a V8 or a V6? You might as well go ahead and give the year too.
Sorry-
It's a 2004 V6.
The 0352 code was marked as "pending" in the software package that I have. 0304 was not marked as pending. I am guessing that means that the 0352 did not cause the CEL to come on (yet). I think that 0304 is cylinder 4, and the 0352 is related to cylinder 2, which means I have 2 problems, most likely both are coil issues.
from here
firewall
3 6
2 5
1 4
bumper
So it appears I could easily fix #4 without removing the upper intake manifold, but I'm shafted on the 0352 (#2).
Dale
Holy quintuple post, Batman!
As you've hopefully seen in your searches, once one coil goes, the rest are seldom far behind. Remember to change the plug on any coil that you replace.
For some reason, the board wouldn't show his posts until now. I could see that he was posting, but couldn't see the posts. I guess he couldn't see them either and kept retrying.
