Berrymarknj
Replaced it for $10. Found it in a junkyard on a 2003 Explorer. Since it was mounted high and dry under the hood and not under the driver’s side front fender it worked. Numbers did not match, used cable from original, connector matched perfectly. Added silicone sealant to the throttle cable flange and some around the motor cover. Some dielectric grease to wire connector and we are cruising again. Just trying to give back.
