Well, I just got back from a long ride (2000 kms) in my 2002 LS V8 that I bought last week. A couple of things I discovered.... Upon setting the cruise, it will work for about 15 mins, then it will mysteriously shut itself off. I will not be able to turn the cruise on again until I actually shut the car off and then start it again. Very strange, any ideas?? The same basically applies for the wipers, only when they are in INT mode. They work fine in high and low, just when they are in INT mode, they will only work for a while or not at all until I shut off and restart the car. Anyone know what could be causing these problems?? I initially thought it could be the clock spring with the cruise issue, but because it will turn back on as soon as the car is restarted, I'm not sure that the clock spring has anything to do with the problem.
