rgorke
So after changing out the Sway Bar bushing, the creak is still there. I even reinstalled and regreased the bushing to no avail.
I had my son jack up the car and I could feel the creak coming from the Lower Control Arm. It isn't a clunk like from the ball joint but a squeak or creak. I also squirted them with some lithium lube and they seem quiet now, I will now more when it heats up.
The price on LCA's is pretty high, so...I came across these posts to install zerk fittings for the bushings.
and
Rear lower control arm bushing replacement (pics)
I think this would be a good thing for all the control arm bushings.
Also, would it be advises or has anyone used a LCA from a junk yard (correct Gen, etc) and re-bushing'd it with a high quality set of bushings? I would do it this way rather than re-bushing my existing LCA because I don't want to leave my car potentially undriveable as I put in the new bushings. I would also probably put zerk fittings on this "new" LCA as well.
Thanks
and
Thanks
