cow like noise
orgulloso4202
Santa Ana
So I notice my ls 2002 v6 3.0 makes this hallow noice when the i turn it on. People have told me it sounds like a cow. I haven't noticed any performance issues. Any ideas what could it be.
do you live on a farm? maybe a baby cow stuck in there somewhere..
a video would probably help if you can
When you turn the key on, when you start the engine, when the engine is running at first? What's a "hallow noice?" (sacred cow sort of thing?) Or if you meant hollow noise, do you mean some sort of echo? I once had a bad IAC make a cow moaning sort of noise on a Grand Marquis.
When I turned on the key and when the car is running. Echo, hollow. Will put a video.i don't know if I can up load it via tapatalk app.
Ok here are the two videos I took hope it helps . Thank you all for you help.
[video]https://youtu.be/5KrHZDoofHM[/video]
[video]https://youtu.be/vM6IBHmUc7Y[/video]
is your air box closed tightly? sounds like the power is trying to get out...
Had that happen to my boy's Crown Vic with the 4.6 V-8 Joe! Was loud enough people looked at him at a stop like he had blown the horn at them.That BUGGER was pretty hard for me to get to,but I did it. don-ohio
sounds like a hole in the exhaust and a failing pulley off something (alt / power steering etc.)
