Could some of you guys help me troubleshoot this issue?
Lincoln Mark VIII
  1. Myco
    Myco Dedicated LVC Member
    913
    7
    Nov 28, 2008
    Houston
    Driving home from work the other day the car started a miss. A VERY pronounced miss that I could feel at 50+mph. Once I came to a stop the car was romping(stumbling) pretty bad.
    I had the codes read and it's po174 bank 2 lean.
    I wondered if it was a COP so I took the covers off and pulled the front COP on the drivers side and the spark plug well had quite a bit of oil in it. Could this have fouled the spark plug?
  2. chris2523
    chris2523 93 Mark VIII
    7,898
    265
    Nov 8, 2007
    Central MO
    the oil will cause the coil to short instead of fire the plug.
    i would clean the oil out and check the plug.
    go from there.
    time for valve cover gaskets though. and maybe a new boot.
  3. slowmkviii
    slowmkviii Dedicated LVC Member
    5,572
    135
    Sep 28, 2007
    Elk River, MN
    I agree with Chris
  4. Myco
    913
    7
    Nov 28, 2008
    Houston
    I took the oil out of the the front plug on the drivers side and I'm guessing it was about a teaspoon. I replaced the boot on that coil. I started swapping out coil's on the drivers side and found it was the 2nd coil from the front. Upon inspection of the OEM coil there was a crack on the top of the coil. Wow...
    Anyway, thanks for the responses. If anyone has this issue and the stumble is persistent through the entire rang of RPM, significant (down on power, lots of shaking in the car, pronounced 'romp' when idling) check the coil's. My engine light never came on but I had a PO174 Bank 2 lean code. 1 coil is 40~ (aftermarket) depending on where you get it. You can swap it out with each cylinder to find the bad coil.
  5. FrankAZ
    FrankAZ Active LVC Member
    160
    42
    Dec 27, 2013
    Phoenix, AZ
    The oil itself can cause the failure also I believe - with that much oil its time for valve cover gaskets and a spark plug seals.
    I paid $212 for a set of OEM Ford Racing coils (fit perfect) for all 8 and thats what is in mine now.
  6. Scallywag
    Scallywag Well-Known LVC Member
    218
    9
    Oct 4, 2010
    Franklin Park
    Thanks for the reminder!!!
    I also have to do the valve cover gaskets on the WF because 4 wells are drowned in oil. I'm quite certain that with as much oil that builds up in the wells, I'd get hydrolock if I didn't do the tedious task of extracting as much oil as I can with the fitting and soaking what remains with a rag before finally feeling comtfortable enough to take off the plugs.
    I already learned the hard way once and certainly dont need a reminder.
  7. Uncle Sherm
    Uncle Sherm LVC Member
    12
    4
    Aug 12, 2018
    Iowa
    I'm going to bump this thread because I had a similar problem this week in my 97 LSC. As I came to a stop light, the engine started feeling pretty rough and the check engine light started blinking. I took it to a shop near work and the mechanic found oil in the spark plug well. Now he wants $2300 to replace the intake manifold gasket, coils, plugs, and valve cover gaskets. I get the valve cover gaskets and the bad plug and coil, but is there any reason they would need to pull the entire intake manifold off for this?
  8. slowmkviii
    5,572
    135
    Sep 28, 2007
    Elk River, MN
    Nope
    • Like Like x 1
    • 91 LSC SE
      91 LSC SE Dedicated LVC Member
      540
      20
      Sep 25, 2008
      Canada
      Is it just the gaskets that get old or is it that the value covers get loose over time and torquing them would solve this?
    • Uncle Sherm
      12
      4
      Aug 12, 2018
      Iowa
      For me, it is the spark plug tube seal that needs to be replaced on the underside of the valve cover. I don't think the valve cover gasket has a problem at all, but I haven't had an opportunity to pull the cover off to find out.
    • mikemark8
      mikemark8 Well-Known LVC Member
      426
      6
      Jun 26, 2007
      willow grove
      If it were me i'd certainly try snugging the covers (after a well clean-up) to see if they still fill with oil. Can't hurt at this point.
    • mikemark8
      426
      6
      Jun 26, 2007
      willow grove
      Clean 'em all out good first, then snug them up. Let us know how it works out.
    • 91 LSC SE
      540
      20
      Sep 25, 2008
      Canada
      I haven't had this issue. I was thinking preventive maintenance. Similar to spraying the IMRC springs twice a year, so they do not get stuck and light up the CEL or hosing out the front side of the back quarter panel to keep that area from rusting out.
    Share This Page
