Coolant woes once again...Sigh
Lincoln LS
  1. AmsterDutch
    AmsterDutch Dedicated LVC Member
    1,854
    311
    Jul 9, 2017
    Midwest
    Well I replaced my upper and lower coolant hoses...DCCV ...Aux Pump ' was ' working good so I kept it ...upon removing the existing DCCV I noticed it was OEM and it looked way to good to be the Original ...so now I'm kicking myself in the ass for changing it out...put in new Generator/alternator and proceed to fill and bleed the system...now while I'm bleeding the system the coolant is rising and boiling over out of DEGAS reservoir ...it goes up and then goes down ...goes up then goes down...repeated this four or five times...coolant was at 112 Celcius while this happened ...the needle stayed in the middle of temp gauge the whole time...is the DEGAS reservoir cracked? Or would this be water pump problems? I also noticed that the heat would get hot and then cool off even while at 90 degree setting...I'm starting to think these cars are possessed by something...once again I'm pulling out my hair trying to figure this out
  2. joegr
    joegr Dedicated LVC Member
    20,040
    1,528
    Dec 10, 2005
    Gulfport
    It sounds like you have a lot of air in there.
    Filling and bleeding is way easier with the car's nose pointed down. It's very difficult with the front pointed up hill or on ramps.
  3. AmsterDutch
    1,854
    311
    Jul 9, 2017
    Midwest
    Thanks for responding Joe ...I was thinking the same thing ...but like always with this coolant system I'm never 100% sure...I will put the car's rear wheels on ramps and keep trying to bleed the air ...I let it rest for 30 minutes and went back out and started it up ...the temp went to 112 celcius again 233 F' and steam was coming out of good g5 degas reservoir...I then added so.e coolant and it stayed at 98 celsius ...only Luke warm air coming out out of heater when it's on 90 degree setting still...I guess I will keep bleeding ...if it's not a successful bleed by tonight ...guess I'll change out degas reservoir next
  4. AmsterDutch
    1,854
    311
    Jul 9, 2017
    Midwest
    Joe one thing I notice just now as I'm bleeding this coolant system...the only way I can get coolant out of the heater bleed hose is by placing the heater bleed hose downward ...I mean I have to push it down past my coil covers otherwise coolant wont bleed out....Any thoughts on this?
  5. joegr
    20,040
    1,528
    Dec 10, 2005
    Gulfport
    Your system is not pressurizing for some reason. You'll have to find and eliminate the leak.
  6. AmsterDutch
    1,854
    311
    Jul 9, 2017
    Midwest
    yup that's what I thought...has to be the degas reservoir...everything else is brand new...thanks for the conformation
  7. AmsterDutch
    1,854
    311
    Jul 9, 2017
    Midwest
    My temperature range since my last drive is between 208-215 Fahrenheit...if plastics are Okay ....where do I start?
  8. Archangel
    Archangel Active LVC Member
    88
    22
    Oct 22, 2015
    Garner
    Check your t-stat...
    Before I noticed my radiator leaking, mine was acting very similar.
    You saw in my post how one of the ears in the T-stat housing had busted, making the T-stat all caty-whompus which was no doubt affecting coolant flow and temp issues.
  9. AmsterDutch
    1,854
    311
    Jul 9, 2017
    Midwest
    I have the Aluminum Uro Jaguar T-stat housing ...remember I'm in a 2002 LSE V8 ;)
    • Like Like x 1
    • Archangel
      88
      22
      Oct 22, 2015
      Garner
      Oh nice.
      I reckon they won’t fit on a 2nd gen V8
    • AmsterDutch
      1,854
      311
      Jul 9, 2017
      Midwest
      Unfortunately no...that would be nice though
    • milehighmikey
      milehighmikey Dedicated LVC Member
      768
      47
      Apr 2, 2007
      Nashua
      This is kind of what led to my engine getting a cooling system compromise a few years ago. It was the hardest problem to t-shoot. After a few hours of changing thermostats and everything else I could think of while being 40 miles from home at work, I finally cracked something and the water started rising up out of the degas with lots of carbon in suspension. The block or a head had cracked. I bought a new V6 with 110K on it the next day, swapped the engine in... My old engine had a 5 year old Autozone water pump in it with lifetime warranty. So I swapped that biotch over to the replacement engine, since it had been sitting a long time and had a rusty drive pulley on the water pump. I started the replacement engine, attempted to bleed it the normal way, no pressure on the heater vent-purge line unless I handed it a couple thousand RPMs. Tried everything but this thing was doing exactly what happened to the original engine! Thought about the DCCV which was not old, that wasn't it. The only thing left to try was the G damned water pump. I pulled it off and low and behold, the impeller was off the shaft! That was my original problem and I had moved it to the new engine! So yeah, I got a free replacement water pump but Autozone said they were not able to help me on the blown engine... Check your water pump before it is too late! Again, same symptom as yours, no pressure or flow on the heater purge line!!! I know, it is a brain buster of a problem for which there are almost no explainable symptoms. Good luck man!
      • Like Like x 1
      • AmsterDutch
        1,854
        311
        Jul 9, 2017
        Midwest
        You know I was actually thinking about the water pump...why I didnt change it is just stupid....by the way...what brand should I go with or do you suggest?
      • AmsterDutch
        1,854
        311
        Jul 9, 2017
        Midwest
        Hey Mike...the only thing that kept me from pulling the trigger is that I think I can actually feel the water moving in the upper radiator coolant hose...not sure but I was squeezing on some of the hoses last night and coolant would come out of the heater bleed hose ...and I swear when squeezing the hoses I could feel the coolant moving in them...not 100% sure ...the water pump is cheap enough to replace so I'm just going to do it
        • Like Like x 1
        • milehighmikey
          768
          47
          Apr 2, 2007
          Nashua
          Hehe after reading my story, I would stay away from Autozone, unless their V8 pump is equipped with a metal impeller. Motorcraft would be my choice if I was to do it again. Good luck bro!
          • Agree Agree x 1
          • AmsterDutch
            1,854
            311
            Jul 9, 2017
            Midwest
            Update: After work I proceeded to try bleeding the system again and had my wife come out and rev it up to 2000-2500 RPMs ...nothing came out of heater bleed hose...would this confirm 100% that the water pump is totally gone?
          • Archangel
            88
            22
            Oct 22, 2015
            Garner
            Mine was doing that exact same thing before I found the radiator leaking.
            My 15 year old water pump was wearing but not shot. I replaced it cuzz it was 15 years old and since I had all the fan shroud/radiator out of the way, seemed like the prudent thing to do.
            mine would only bleed with the engine above 1500 rpm and only weak like.
            hope this may help.
          • AmsterDutch
            1,854
            311
            Jul 9, 2017
            Midwest
            There is a hose with a middle aluminum connector that goes from the T-stat housing and has another hose connect to the aux pump...I'm almost wondering if that rubber hose that is crimped with the aluminum adapter might be shot...It certainly looks a little sketchy to say the least ...while visually inspecting the radiator...I cant ser any coolant leaking from it ...I will give it a better look after work tonight...I ordered the water pump ...should be here by the end of the week. ..I hope ...the temp outside is rising and I need to get this under control quickly
          • AmsterDutch
            1,854
            311
            Jul 9, 2017
            Midwest
            After replacing the water pump and degas reservoir now I have just the opposite problem ...Coolant is shooting out of the heater bleeder valve like a hose...this is almost comical...Is this car possesed?
          • AmsterDutch
            1,854
            311
            Jul 9, 2017
            Midwest
            By the way my car was still overheating and steam was shooting out of the heater bleed valve like a steam kettle! I'm bringing it to a shop to have it professional bled tomorrow...I will give you an update how it goes
          • AmsterDutch
            1,854
            311
            Jul 9, 2017
            Midwest
            I think I'm going to get it checked for a blown Head Gasket while I'm there...just wanna make sure I'm not wasting my time with all this bleeding
          • AmsterDutch
            1,854
            311
            Jul 9, 2017
            Midwest
            Wow! just amazing the knowledge this Lincolnvscadillac forum produces from Senior members who have worked on these cars for years and years...Joe you were right I had a huge air pocket in the system ...after having it bled professionally today I'm sitting at 195F and doesn't go past 205 at highway speeds ....Once again you were spot on...Mike you were right also...upon removing the water pump the plastic ring had corroded of and was stuck up in the propeller channel... I also replaced the Degas reservoir...with that being said you can go from underneath the car and fit your hand on the hose to slide it nice and easy onto metal adaper line...not sure if this was ever noted...I never seen it in any post...hope it helps out the next guy....but thanks for all your help Joe and Mike!!! You saved many gray hairs lol
            • Like Like x 2
            • milehighmikey
              768
              47
              Apr 2, 2007
              Nashua
              Right on man! Effing water pumps can be such a b*tch to troubleshoot. It cost me an engine!
              • Like Like x 1
              • AmsterDutch
                1,854
                311
                Jul 9, 2017
                Midwest
                Mike you're a Fing Life saver!!!!!! Thank you so much for chiming in and saving me a lot of heartache....That could've ended really badly...Thanks so much man!
                • Like Like x 1
                • milehighmikey
                  768
                  47
                  Apr 2, 2007
                  Nashua
                  You got it Dutch! Anytime I can help, I will.
                  • Like Like x 2
                  Share This Page
