grizzlyls
SO with my weird arse overheat two weekends ago (not a problem since) I have been monitoring the temps 100%. Its made me think I should run an unpressurized system.......
Ya Right. Anyhow, what I do see is a trend after my high speed highway travel, the ridiculous stop and go here in the LA cities means less air flow. When it has air flow its perfect. Gen 1 fan system is working, I hear it ramp up, I see the coolant temp dip, but I think with the conditions here its a step and a half forward then a step back. Slowly the overall temp rises.
Reading up on things I think I should get off the simple 50/50 green I have been buying and go to something closer like 70/30 (more water). It is said water is more efficient at cooling, so maybe that will give me the boost to handle the in town shiot a little better. As far as anti freezing, I have not seen the under side of 32 degrees here in So Cal since I moved here in 2008
Opinions? Whats the best way to work the distilled water in - Pull it from degas and fill or from the tsat housing? Should I just top off degas bottle to cold full over the next few days til I use up a half gallon of distilled instead?
My thoughts are system has like 3 gallons, so replacing half gallon with distilled should get me near 70/30.
